iacv n idle question
ok i cleaned my iacv today to try to fix my idle problem n it kinda worse it idle under 1k. and my car feels like its gonna die when im at a light. i friend told me to do something with my coolant but idk. anyone here have the same problem?or know whats wrong? lmk plz
Re: iacv n idle question
man really dont know how to solve the problem but if it makes you feel better all three of my honda's are doing this and i cant figure it out sounds like all of them do it and everone says its the iacv but i tried to clean mine and it didnt help either
is it just idling low? what vehicle? have you tried to adjust the timing with a timing gun?
if your 0BD1 check the FICV under the throttle body some times you need to take off the back and tighten up the big white disc with a large flat tip screwdriver.
also try this
Idle Speed Setting ----------------------..
InspectlonlAdjustment
NOTE: (CANADA) Pull the parking brake lever up.
Start the engine, then check that the headlights are off.
1. Start the engine and warm it up to normal operating
temperature (the cooling fan comes on).
2. Connect a tachometer.
3. Disconnect the 2P connector from the EACV.
4. Start the engine with the accelerator pedal slightly
depressed. Stabilize the rpm at 1000, then slowly
release the pedal until the engine idles.
5. Check idling in no-load conditions: headlights,
blower fan, rear defogger, cooling fan, and air conditioner
are not operating.
Idle speed should be:
Manual D15Z1 engine: 420 ± 50 rpm
Others: 420 ± 50 rpm
Automatic 420 ± 50 rpm (in [N] or [P])
Adjust the idle speed, if necessary, by turning the
idle adjusting screw.
6. Turn the ignition switch OFF.
7. Reconnect the 2P connector on the EACV, then
remove BACK UP fuse in the under-hood fuse/relay
box for 10 seconds to reset the ECU.
8. Restart and idle the engine with no-load conditions
for one minute, then check the idle speed.
off.
Manual D15Z1 engine: 600 ± 50 rpm
Others: 670 ± 50 rpm
Automatic 700 ± 50 rpm (in [N] or [P])
9. Idle the engine for one minute with headlights (Hi)
ON and check the idle speed.
Manual D15Z1 engine: 700 ± 50 rpm
Others: 750 ± 50 rpm
Automatic 750 ± 50 rpm (in [N] or [P])
10. Turn the headlights and rear defogger off.
Idle the engine for one minute with heater fan
switch at HI and air conditioner on, then check the
idle speed.
Manual D15Z1 engine: 810 ± 50 rpm
Others: 810 ± 50 rpm
Automatic 810 ± 50 rpm (in [N] or [P])
NOTE: If the idle speed is not within specification,
see System Trobleshooting Guide on page 11-82.
also try this
are not operating.
off.
idle speed.
c for sea
22
09-19-2006 11:02 PM
