Vtec Not working!!!!!!!!!searched....................
Old Dec 8, 2007 | 01:36 PM
b16civster's Avatar
Default Vtec Not working!!!!!!!!!searched....................
its a lsv.... it has oil pressure and the solonoid works fine.... the solonoid is getting power but still not engaging... the screens are squeeky clean... any help would be mint...also no check engine lights
i also checked to see if the pins are in the rockers and they are....
so now my only thought is that there is a oil passage that is clogged that is feeding the rockers.... do they get fed threw rocker arm rods??? please help
Old Dec 8, 2007 | 05:06 PM
b16civster's Avatar
Default Re: Vtec Not working!!!!!!!!!searched.................... (b16civster)
help
Old Dec 9, 2007 | 07:41 AM
b16civster's Avatar
can i also throw in thats its a fresh build
Old Dec 9, 2007 | 01:16 PM
b16civster's Avatar
up
Old Dec 9, 2007 | 04:24 PM
b16civster's Avatar
again.... i thought this was the tech section.....
Old Dec 9, 2007 | 04:38 PM
killerdx's Avatar
do u happen to have a conversion harness on it? Yea no one wants to help out on this site
Old Dec 9, 2007 | 05:02 PM
b16civster's Avatar
Default Re: Vtec Not working!!!!!!!!!searched.................... (killerdx)
yah i have the conversion harness tis is like my 4th swap and im deff far from a noob all the basic stuff have been checked.. the pressure switch is new the solinoid works and is getting 12v at set rpm and i have 65psi oil pressure at 3500rpm...
Old Dec 9, 2007 | 07:46 PM
killerdx's Avatar
the reason i asked about the conv. harness is b/c sumtimes the wires will pull out of it. It happend to my harness and had to have sumone sauder the pins back in. The only thing mine was doing is what yours is, everything was fine but v-tec wouldnt work
Old Dec 9, 2007 | 07:53 PM
b16civster's Avatar
if it was un pluged you would have gotten a check engine light
Old Dec 11, 2007 | 06:15 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
speedo work *******?
coolant temp on head the two wire one.
vtec solenoid
vtec pressure
thats it if you have all that thats all you need
Old Dec 11, 2007 | 06:38 PM
b16civster's Avatar
Default Re: Vtec Not working!!!!!!!!!searched.................... (NHswaps13203)
its working now... it had some nasty sludge in the bottom of the fresh oil pan on a fresh build....?????? dont know how thats possible
yay lmk when your ready to test it
Old Dec 11, 2007 | 06:45 PM
b16civster's Avatar
hoping on the asap
worx
Oct 18, 2009 08:52 AM
civic-one
Aug 10, 2009 05:58 AM
LudeJdm
11
Jun 19, 2005 06:23 PM
LudeJdm
May 29, 2005 09:53 PM
LudeJdm
May 29, 2005 09:52 PM
