vtec help
Old Oct 17, 2009 | 07:57 AM
worx's Avatar
Default vtec help
ive been running my h22 for a bit now and people tell me my vtec aint working i start paying more attention to it and yiou cant hear it,i have full 2.5 in piping headers and cai i also get cel 22 for vtec pressure switch sometimes. i checked the vps for continuty check for the voltage on harness its suppose to have approx 12. i kepp getting 11.7 doubt if thats my problem my soleniod clicks when straight power is ran to it. tried diffrent ecus same issue. any help would be appreciated thanks in advance
Old Oct 17, 2009 | 10:33 AM
TegRr's Avatar
Default Re: vtec help
Have you checked the oil level as that will affect vtec engagement? That or check the pressure switch.
Old Oct 17, 2009 | 05:57 PM
worx's Avatar
yes checked the oil its good though my oil light has been blinking once in a great time. i checked the pressure switch its good i even swapped it wuth a working one
Old Oct 17, 2009 | 06:19 PM
DAintegraGSR's Avatar
did the oil pressure light still blink when you swapped it with the other one??
Old Oct 17, 2009 | 06:34 PM
worx's Avatar
it blinks once in a good while. couldnt it mean my oil pressure sensor going out
Old Oct 17, 2009 | 09:28 PM
TegRr's Avatar
Check the wiring. Is this a swap?
Old Oct 18, 2009 | 08:52 AM
worx's Avatar
checked the wiring on the ecu side and in the engine it read 11.7v in the manual it says it should be aprrox 12.v. yes this is a swap. imma swap out the whole vtec with the one from my other h22 see if that helps
94wip
12
Jun 20, 2024 07:23 PM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
hellogsr
Oct 11, 2006 09:29 AM
BeeResp0nsible
Nov 29, 2002 05:43 AM
