Whats the maximum boost you can make on a 0.3bar 4.4psi Tial SMALL GREEN spring?
Old Dec 7, 2007 | 01:44 AM
0TT's Avatar
0TT
Default Whats the maximum boost you can make on a 0.3bar 4.4psi Tial SMALL GREEN spring?
Im using hondata with GM solenoid.
Cheers
Old Dec 7, 2007 | 03:36 AM
non-VTEC's Avatar
Default Re: Whats the maximum boost you can make on a 0.3bar 4.4psi Tial SMALL GREEN spring? (0TT)
im getting 17psi pretty solid out of that little spring using the AVCR on a 38mm gate.
**edit**
http://www.tialsport.com/prod_wg.htm
the small yellow spring is .2 or .25 bar depending on the size wastegate.
the small green is .4 or .5bar depending on the size of the wastegate.
im using the small yellow spring and it seems to hold 17psi pretty well...
Modified by non-VTEC at 8:18 AM 12/7/2007
Old Dec 7, 2007 | 03:59 AM
187Chor's Avatar
im using the small green in a 44mm i thought it was .4 bar in the 44mm and .5bar in the 38mm.. no?
(not sure what the max boost u can run tho is)
Old Dec 7, 2007 | 01:37 PM
thomas@LPS's Avatar
i couldnt get more than 17lbs on the .25 bar/3.6psi one with a profec b2.. i would imagine you could get another pound or two out of the .3 bar.. i would recommend getting a higher spring pressure im runing a small yellow and a large yellow and spool time is about 200rpm quicker on the exact same setup..
RedR
Apr 27, 2006 08:06 AM
eg:R
Mar 6, 2006 01:15 PM
lanojp1
Aug 26, 2004 10:01 AM
jure
May 6, 2004 02:32 PM
ridnmyhonda
Apr 4, 2003 06:33 AM
