Need help identifying my tranny
Old Dec 6, 2007 | 03:45 PM
Historyg's Avatar
Default Need help identifying my tranny
Hey guys, here is the story, my hx tranny went out while ago, bought a So called 96 ex tranny from this local on craigs list, it was fine syn's good nice insides, but i have no clue what tranny it is, when driving it feels like the ex, but have no idea, and there are no vin #'s on it at all, it has the thick shift forks not the aluminum ones, does that make it a 92-95 tranny, I dont know, because i want to buy a input shaft bearing in it, and i got one for a 96 ex, and i dont think it is going to fit, input shaft seems a lot smaller, any help would be great, or any secret way to tell what tranny it is when its on the car, because i dont have it off yet, i am trying to get the parts first, well thanks sorry for the silly question, i just cant find out
Old Dec 6, 2007 | 03:49 PM
schardbody's Avatar
if you are sure it has the steel shift forks and not aluminum then its for sure 96+, you just need to look on the end of the case above the fill plug for the circle, inside that circle should be cast A00 or B00
B00 is EX
roycivic92's Avatar
Default Re: Need help identifying my tranny (Historyg)
the have a number code on the side . A000 or B000
A000 means its a cx,dx,hx
B000 means it s a ex or si
Old Dec 6, 2007 | 03:53 PM
blk92_d16's Avatar
Sounds like you got a dx instead...sorry. Ex = larger bearings, Dx = smaller bearings. And if the forks are larger/thicker, then they're aluminum too!
Old Dec 6, 2007 | 04:02 PM
ejoner's Avatar
Default Re: (blk92_d16)
If it doesn't have a vin plate on it then it isn't a 96+ unless someone removed it but that would be obvious. Look for a raised stamp on the case should be near the drain or fill plug that says A000 or B000. What shift fork are you talking about? clutch fork?
Old Dec 6, 2007 | 04:08 PM
Historyg's Avatar
the tranny looks like this the diy from the input shaft bearing
https://honda-tech.com/zerothread?id=596873
the forks are thick like that, and that tranny is off a 92-95 that is why i am wondering, i am just posting this in reply i didnt get my lazy *** downstairs to check the tranny because it freaking snowing and i just got back from 9 hours of class, but yea that is what the tranny i have on now looks like
Old Dec 6, 2007 | 04:09 PM
Hittnthebz's Avatar
this is very informative. does the A000 B000 thing apply to b series trannys also and if so, what letters/numbers will b-series trannys have?
Old Dec 6, 2007 | 04:24 PM
roycivic92's Avatar
Default Re: (Hittnthebz)
no, d series only
Old Dec 7, 2007 | 12:08 AM
Historyg's Avatar
bump for a little more help sorry guys
Old Dec 7, 2007 | 11:35 AM
blk92_d16's Avatar
Yes, that is a '92-'95 model year tranny in the DIY...and yes, you have a '92-'95 model year tranny. After you throw on your coat and take the 10 seconds to look at the casting mark right next to the drain plug you'll see the A000 or B000. You'll wanna hope for B000...
civic95hbvtec
Nov 25, 2007 05:59 PM
2muchPSI
May 30, 2005 10:15 AM
tolowhb
11
Aug 10, 2003 04:36 PM
5thGhB
Aug 7, 2003 07:30 PM
CzanSOHC
Sep 5, 2002 07:22 AM
