EX tranny guys....
Old 08-10-2003, 09:13 AM
tolowhb's Avatar
Default EX tranny guys....
Hey, I am trying to figure out for sure if I have an ex tranny on my d16z6 swap that I just did, are there anyways to verify this by the tranny housing? Oh and I dont have a tach but when I am in second gear I shift @ about 35 mph and the motor is wound up pretty well. Does this sound like an ex/si tranny?
Old 08-10-2003, 09:26 AM
tolowhb's Avatar
Default Re: EX tranny guys.... (tolowhb)
bump
Old 08-10-2003, 09:36 AM
tolowhb's Avatar
Help
Old 08-10-2003, 10:01 AM
RickChew's Avatar
Theres is tranny code, I will look into what the codes are. It should be a letter and then 2 numbers. Rick
csprague's Avatar
With the EX tranny 7200rpm - 34mph, so at 35mph you should be pretty close to smacking the rev-limiter. I am not sure exactly where it is set though, maybe someone else could help?
Old 08-10-2003, 10:13 AM
dynomax27's Avatar
Default Re: EX tranny guys.... (csprague)
Well i like to think of redline in the ex tranny as every 30mph. So a 30mph i redline first, 60mph red line 2nd and so on. i think 3rd might be like 85 or something but close enough to the 30 rule.
Old 08-10-2003, 10:50 AM
tolowhb's Avatar
Default Re: EX tranny guys.... (RickChew)
I am pretty sure it says "p20"
Old 08-10-2003, 10:57 AM
tolowhb's Avatar
Whatever the code is, I think my dx tranny had one very similar, but very diffrent serial numbers.
Old 08-10-2003, 11:05 AM
Daniel's Avatar
Search for a member named Mista Bone. He has a tranny webpage he made. That should help you out.
vladd's Avatar
Default Re: EX tranny guys.... (dynomax27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynomax27 &raquo;</TD></TR><TR><TD CLASS="quote">Well i like to think of redline in the ex tranny as every 30mph. So a 30mph i redline first, 60mph red line 2nd and so on. i think 3rd might be like 85 or something but close enough to the 30 rule.
on my 97 y8, its the rev limiter is at 35, 60, 90
Old 08-10-2003, 11:41 AM
NonovUrbizniz's Avatar
Default Re: EX tranny guys.... (civicdxtyper)
http://home.cinci.rr.com/mistab0ne/tranny.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://home.cinci.rr.com/mistab0ne/tranny.html &raquo;</TD></TR><TR><TD CLASS="quote">
You can tell a DX/CX/VX tranny from a EX/Si by numbers cast into the housing. Just above the filler plug is a set of numbers.
P20/A000 is for DX/CX/VX
P20/B000 is for EX/Si
Other than that, tranny must be split apart to know for sure which one you have.</TD></TR></TABLE>
Old 08-10-2003, 04:36 PM
tolowhb's Avatar
Default Re: EX tranny guys.... (NonovUrbizniz)
Sweet, My tranny code does in fact match the one for the ex/si. Thanks!!
nebrown1
04-17-2007 04:14 PM
skrewdriver88
01-17-2006 05:49 PM
JDMlyfestyle
18
06-17-2003 10:21 PM
turbod16y7vtec
12-12-2002 09:22 AM
CzanSOHC
09-05-2002 07:22 AM
Quick Reply: EX tranny guys....
