JDM Piston Compression ?
Old Dec 4, 2007 | 05:08 PM
thirdgod's Avatar
Default JDM Piston Compression ?
Anyone know what individual cylinder compression #s a B18C5 with JDM ITR pistons should put down?
Old Dec 4, 2007 | 05:20 PM
GO-FIGHT-KILL's Avatar
11:1CR, with stock headgasket and no head milling.
Old Dec 4, 2007 | 06:21 PM
RPRacing's Avatar
i assume he's asking for compression test numbers.
nearly the same as USDM
180-200. just make sure they're all the same/close
Old Dec 4, 2007 | 06:24 PM
*smacks forehead* Good catch.
Old Dec 4, 2007 | 06:25 PM
BlueR's Avatar
Default Re: (RPRacing)
also remember that not every gauge reads the same
so even if yours reads 140, don't freak out...
as long as they all read 140, then you're good to go
Old Dec 4, 2007 | 06:56 PM
D's Avatar
D
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">as long as they all read 140, then you're good to go</TD></TR></TABLE>
Until you stick that same compression tester a low comp motor and pull 140 also.
Old Dec 4, 2007 | 07:01 PM
BlueR's Avatar
Default Re: (D)
then hes got bad compression in all 4 cylinders?
if so, time to go to town on that ****
Old Dec 4, 2007 | 10:12 PM
tartje's Avatar
Default Re: (BlueR)
mine blew off the end of the gauge, 250+ on all 4, bottom end standard B18C6
Old Dec 5, 2007 | 02:56 PM
Bbasso's Avatar
Default Re: (tartje)
years ago I tested my motor... 235-230. (USDM)
Now I don't dare to test Just drive & add oil til...
But for a higher compression motor it might read higher, but as mentioned- if they are all the same on a working guage, you're good to go.
Old Dec 5, 2007 | 03:01 PM
BlueIntegraBoy's Avatar
Default Re: (Bbasso)
My B18C was 245-250
dc4teg95
Nov 6, 2007 04:18 AM
SilverPanda
Oct 9, 2007 10:25 PM
i20ar
Sep 17, 2005 12:48 PM
Nikoli
Oct 3, 2004 02:33 PM
