JDM Piston Compression ?
also remember that not every gauge reads the same
so even if yours reads 140, don't freak out...
as long as they all read 140, then you're good to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">as long as they all read 140, then you're good to go</TD></TR></TABLE>
Until you stick that same compression tester a low comp motor and pull 140 also.
years ago I tested my motor... 235-230. (USDM)
Now I don't dare to test
Just drive & add oil til...
But for a higher compression motor it might read higher, but as mentioned- if they are all the same on a working guage, you're good to go.
Just drive & add oil til... But for a higher compression motor it might read higher, but as mentioned- if they are all the same on a working guage, you're good to go.
Nextelbuddy
Jan 9, 2004 06:18 PM
