CLEANED IAC!!! still idels like CACA
Old Dec 4, 2007 | 08:14 AM
MiamiEgGSr's Avatar
Default CLEANED IAC!!! still idels like CACA
OK ... I CLEANED MY IAC YESTERDAY !!! car started up fine , no prblem drove around , no problem,,,, as soon as i GUNED it and took it to 6,000 , chech engine came on.. **** idles like crap!!!!
yes i cleand it with brake cleaner ( i even tried a liitle WD-40 on another i had)
yes i reset the comp!
wat can i do !!!!!
Help a bro out... its a jdm b18c with the stock GSR manifold!!!
Old Dec 4, 2007 | 12:53 PM
MiamiEgGSr's Avatar
Default Re: CLEANED IAC!!! still idels like CACA (MiamiEgGSr)
aww a little help Por Favor
Old Dec 4, 2007 | 12:59 PM
all-mtr-teg's Avatar
Whats the CEL code?
Old Dec 4, 2007 | 02:27 PM
MiamiEgGSr's Avatar
Default Re: CLEANED IAC!!! still idels like CACA (all-mtr-teg)
14
Old Dec 4, 2007 | 02:37 PM
Did you reset the ecu after you cleaned the IACV? Also make sure its torqued down correctly and the plug is hooked up tight. Also, why did you spray WD40 into it?
Old Dec 4, 2007 | 04:41 PM
MiamiEgGSr's Avatar
yes its reset , and i tried wd-40 on onw of the to see if it woul dmake a difference.. apperantly it did not
Old Dec 4, 2007 | 09:21 PM
bschulz's Avatar
If by gunning it you mean you warmed it up and then the code was thrown, you may just have a bad IAC altogether. If you've cross-checked it with a known-good IAC you may have a bad connection.
Old Dec 5, 2007 | 01:50 AM
nonbox's Avatar
I cleaned a IAVC on a DC2 w/carb cleaner and it ran fine for a day then it went back to an bad idle. Solved the problem by buying a new oem IAVC for $180 online and after I installed it, all the problems went away.
Old Dec 5, 2007 | 06:49 AM
MiamiEgGSr's Avatar
Default Re: (nonbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonbox &raquo;</TD></TR><TR><TD CLASS="quote">I cleaned a IAVC on a DC2 w/carb cleaner and it ran fine for a day then it went back to an bad idle. Solved the problem by buying a new oem IAVC for $180 online and after I installed it, all the problems went away.</TD></TR></TABLE>
i think I HAVE NO CHOICE BUT TO AGREE..lol
kyang03
Aug 7, 2012 12:16 AM
zero708970
24
Jan 25, 2010 09:08 AM
GiT LaO'd
Feb 10, 2005 05:49 AM
Thrillhouse
Sep 5, 2004 04:40 PM
sleepyhamsterlx
Dec 10, 2003 07:43 AM
