Throwing cel code 14, IAC what to test?
Old Aug 15, 2004 | 05:33 PM
Thrillhouse's Avatar
Default Throwing cel code 14, IAC what to test?
I was driving and all of a sudden my car started to idle like crap around 1200 and moving up and down very rapidly. So I got home and pulled the code and it is 14 IAC. What should I start by checking?
Old Aug 16, 2004 | 04:50 AM
Default Re: Throwing cel code 14, IAC what to test? (Thrillhouse)
anyone?
Old Aug 16, 2004 | 06:04 AM
-faded-'s Avatar
prob have to change your iac valve. backside of the intake mani
Old Aug 16, 2004 | 07:53 AM
rsbad454's Avatar
Default Re: Throwing cel code 14, IAC what to test? (hybridlsR)
probably search is your friend
Old Aug 16, 2004 | 09:45 AM
Default Re: Throwing cel code 14, IAC what to test? (rsbad454)
I did search I found a few things like try to clean it and stuff, but no real diagnostics.
Old Aug 21, 2004 | 01:58 PM
integrx's Avatar
New User
well if you haven't fixed your problem yet, try
1. take the iacv sensor off, it has 2 bolts, and spray the dirty sensor off with some carb cleaner.
2. if that doesn't work try replacing it.
I'm have the same trouble and did everything and CEL still won't go away.
Old Aug 21, 2004 | 04:41 PM
almtr2.2's Avatar
Default Re: Throwing cel code 14, IAC what to test? (integrx)
If you have the "up and down idle" syndrome (sucks at stoplights, high?) sounds like it could be a leak in the mani. That will cause your ECU to throw a code like that or similar....did you check all your vacuum lines and plugs, etc.?
Old Aug 21, 2004 | 05:56 PM
integrx's Avatar
New User
I can't even idle, the car dies out when the foot is off the gas. So i have to keep the foot on the gas so the RMPs don't fall to 0 causing the car to die out.
Old Aug 21, 2004 | 08:33 PM
EG6AAARRR!!!'s Avatar
i am throwin the same code...i was also told that i have an opening on the backside of the manifold that if i was to put my finger over it, the idle would drop and almost kill the car..i havent looked at it yet...
Old Aug 21, 2004 | 11:30 PM
vtecb20coupe's Avatar
B A N N E D
if you've cleaned it already and still have the problem. you may want to replace it. there's no way around it.
Old Sep 5, 2004 | 04:40 PM
civlude's Avatar
YEAH IM A NEWBIE. But at least I Can say that I never had to take my car to the shop, I fixed all problems myself.
I FIXED IT!!!! I had CEL #14. I had the same problem, engine would die out at stops. It also would bog real bad that my whole car would shake (AT 1,500-2,000 RPM). I found out that my IAC sensor WIRE WAS SLICED for some reason. I checked the sensor wire for good connection with a fuse checker, and there was no path. So I checked the wire and sure enough that was it. So check your wiring before you start buying anything. This didnt cost me a penny. CHECK YOUR WIRING!!!
~CIVLUDE~
'93 civic EJ1 w H22A
dragon_lowrider
Sep 22, 2010 10:55 PM
reed857
29
Jul 26, 2009 10:57 AM
SONIC BOOM
Jul 10, 2006 10:54 AM
