oil return line?
Old Nov 30, 2007 | 08:01 AM
mma82's Avatar
Default oil return line?
ok set up is drag turbo kit w 3" down pipe and exhaust on a b18c in a 96 civic coupe. after the install i saw my car on the lift and noticed the oil return line looked restricted and was touching the exhaust pipe the part that bolts up to the pan anyway but the line is still really close. would that really get in the way of cooling off the turbo and would that burn the line off? what are some options to take care of that? diff pan and putting a hole somewhere else, rearrange the line? went to experienced installers
Old Nov 30, 2007 | 08:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: oil return line? (mma82)
cooling maybe, burning a hole in it probably.
i had to kinda go around the corner on my drag kit. as long as you keep it sweeping down and no kinks you can get away with it.
Old Nov 30, 2007 | 04:46 PM
JaredKaragen's Avatar
Default Re: oil return line? (boostedcivicsir)
I fyou check out alot of OEM turbo'd cars, they have fiberglass /metallic cloths that can be snapped on and off of lines/hoses/etc and I took one off of a line from a Jetta, and put it over my return line, but cut it in 1/2 so that I could have one piece at each point on the return line where it was close to the DP.
jacob4lester
Feb 16, 2010 08:36 PM
pjr710
Jan 14, 2010 03:28 PM
WildChild
Sep 15, 2005 08:35 PM
Trigun
Jun 17, 2002 10:47 AM
