swap opinions for my 95 teg
Old Nov 27, 2007 | 06:02 PM
BG-Teg's Avatar
Default swap opinions for my 95 teg
im stuck between doing a b20/vtec with my gsr head or buying an h22 and doing h2b, i have the money for both but wat do u thnk would be the best daily driven
Old Nov 27, 2007 | 06:31 PM
BG-Teg's Avatar
Default Re: swap opinions for my 95 teg (BG-Teg)
bump
Old Nov 27, 2007 | 07:07 PM
LemonsEH2's Avatar
why not keep the gsr? and boost?
Old Nov 27, 2007 | 07:43 PM
BG-Teg's Avatar
Default Re: (LemonsEH2)
becasue the valves are bent and i figured while the heads off for b20/vtec i can fix all that then put it on another block to get some more tourqe, and i cant really afford boost at the moment
Old Nov 27, 2007 | 07:47 PM
posHonda's Avatar
h2b and while you drive that build the gsr.
Old Nov 28, 2007 | 11:04 AM
SuckMyDOHC's Avatar
Neither. If you want something reliable, build up your head since your valves are beant. New cams, valvetrain, port and polish, intake manifold, etc. Then next, work on your block. Get some oversized JDM ITR pistons along with ARP rod bolts and a micropolished LS crank
Old Nov 28, 2007 | 11:23 AM
alexisthemovie's Avatar
keep your gsr block and build it. Build the head with full valvetrain/cams.
Old Nov 29, 2007 | 04:41 AM
AWD Terror's Avatar
Default Re: (alexisthemovie)
You don't have the money to boost your GS-R, but you have the money to do a h2b?
Niether one of the engines listed would be as reliable as your GS-R
Old Nov 29, 2007 | 11:58 AM
yc_dc4mar's Avatar
a proper b20 build can be very reliable actually. just dont boost it.
GSR_hatch936
Oct 5, 2009 06:01 PM
G-Auto*Hero
Jul 20, 2009 10:41 PM
mysterysktr7
Jun 18, 2009 02:14 PM
Mikej425
Jun 14, 2008 06:46 PM
GreenGSR
Nov 25, 2002 10:34 PM
