maintenance required light question
so awhile back my ac belt snapped and i never got around to replacing it, and every
time i start my car the maintenance required light flashes several times then goes away.
so last night i put my winter tires on my car, and this morning it was a constant, no
flashing and remains on (only reason i mention the changing of the tires is it was the last thing i did to the car before the light remained constant). the car is not acting differently or sounding differently. no other belts or anything noticeable like that have failed. the reason for the light remaining constant puzzles me. any insight would be appretiated.
thankyou.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g3Gsr443 »</TD></TR><TR><TD CLASS="quote">just changed the oil like a few weeks ago, which reset button? </TD></TR></TABLE>
Your computer doesn't know when you change your oil....
https://honda-tech.com/zerothread?id=2143378
but it's not just for your oil
it's for honda's suggested scheduled maintenance thing....when it was implemented the intention was to have the dealer ONLY be the one to turn it off after service was complete (pretty dumb on Honda to think the vehicle owners wouldn't turn it off themselves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rainmaker »</TD></TR><TR><TD CLASS="quote">The answer to your question in in the FAQ.</TD></TR></TABLE>
i found cel and abs codes in the faq but nothing about maintenance required lights...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraRS-T »</TD></TR><TR><TD CLASS="quote">its going to come on every 7.500miles the reset button its under the dash pretty much above ur right knee ,just hold it down till it flashes than ill go away</TD></TR></TABLE>
do i have to remove any parts of the dash? I've looked for this button and cant seem to find it
if someone has a picture or diagram of where this button is supposed to be id appreciate it if they would enlighten me on its whereabouts.
stick your head under the driver side dash. Attached onto the plastic dash cover, you'll see a black box with a blue button. Hold it down for a few seconds and you're done.
https://honda-tech.com/zerothread?id=2162114
There's a picture on that page that tells you where it is.
A picture holds a thousand words.
By teh way, how do you post pictures O.o
thanks!
to post pictures you have to have an account at a image sharing website (photobucket) is what i use. and you upload you photos onto that account. and it will the give you an image code or adress just copy and paste that into your post and the picture should appear<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCter VTEC »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=2162114
