bypass oil pressure switch
Old Jun 25, 2002 | 10:36 AM
chirp3rd's Avatar
Default bypass oil pressure switch
if i use a rpm activator or a vtec controller to run my vtec will it bypass the use of the oil pressure switch on the vtec soleniod or do i need that switch to run vtec regaurdless
Old Jun 25, 2002 | 11:39 AM
sgT's Avatar
sgT
Default Re: bypass oil pressure switch (chirp3rd)
vtec controllers will generally bypass it.
its easy to bypass w/o a controller though
Old Jun 25, 2002 | 12:19 PM
chirp3rd's Avatar
Default Re: bypass oil pressure switch (sgT)
can you tell me how
Old Jun 25, 2002 | 12:21 PM
sgT's Avatar
sgT
ground it
Old Apr 2, 2004 | 05:44 PM
gotsmokedright2's Avatar
what wire is ground? what do i do with the other wire?
i dont wanna spend $80 on a new sensor.
Old Apr 7, 2004 | 05:08 PM
Default Re: bypass oil pressure switch (gotsmokedright2)
toying with my multi-meter i found that 1 wire is a ground. the other is the signal wire?
i grounded the signal wire and code 22 still comes on in 3rd gear vtec .
i have a 97 gsr usdm. wtf?
Old Apr 15, 2004 | 06:36 PM
aut0tek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotsmokedright2 &raquo;</TD></TR><TR><TD CLASS="quote">
Only in 3rd gear?
Did u install m4d 3rd g34r vt3c y0! on your car yet?
LMAO sorry sorry sorry couldn't resist.
Ratliff
Old Apr 15, 2004 | 06:44 PM
krazie1's Avatar
BANNED
Default Re: bypass oil pressure switch (aut0tek)
if u interested I got mine
i don't need any longer as I got apexi vtec controller
let me know
pm is the key
See Are X
Sep 4, 2024 03:31 PM
91 DA Revived
Oct 28, 2010 05:25 PM
JSPECSIR
Oct 7, 2008 06:56 PM
Bimmerman
Jun 15, 2005 05:23 PM
B_CRUZ!
22
May 13, 2004 09:00 PM
