Wierd starter Problem.
Old Nov 22, 2007 | 08:17 AM
kyleviney91da's Avatar
Default Wierd starter Problem.
My Friend has a 2000 Si and the starter recently went out. Before it worked fine that after a couple of months it started acting wierd as hell. It would click like 5 times. try to turn the motor twice then finally would start it up. Now it just doesn't work at all. Has anyone heard of this happening before? because i dont want her to waste a bunch of money and just have me throw a new one in there.
Old Nov 22, 2007 | 10:05 AM
VTAC-KAT's Avatar
Default Re: Wierd starter Problem. (kyleviney91da)
sounds like the solenoid that is on the starter which is a common problem on import starters
is the clicking coming from under the dash or the starter?
Old Nov 22, 2007 | 10:08 AM
gezzuzz's Avatar
the starter has 2 wires... one big one for teh battery and one small one.. unplug the small one and get a wire (speaker wire will work) and connect it to the battery.. (make sure your out of gear.. if the car tries to start you know your starter is good
Old Nov 22, 2007 | 01:57 PM
Pure Sol's Avatar
Default Re: (gezzuzz)
Having a similar problem with my del sol VTEC. I've been through 4 starters with each one failing a month to 2 months after. Be careful with that hot wire trick but let me know if you find anything out. Good luck
Old Nov 22, 2007 | 02:56 PM
Yeah i was thinking it was the solenoid to.. But the click normally indicates the starter solenoid to be energized. i'll have to take some dvm readings to be sure
phish4709
Feb 29, 2008 06:55 PM
airsodam
Jan 30, 2006 10:55 PM
91HATCH
Apr 30, 2005 06:23 PM
TypeSH
Feb 22, 2005 09:14 PM
crx1856
Aug 20, 2003 10:24 PM
