Honda S2000 Honda S2000
What is wrong with my Idle? Car turns OFF!
Old Nov 19, 2007 | 08:49 AM
jdm j's Avatar
Default What is wrong with my Idle? Car turns OFF!
My RPM's are going below 1000(Idle) whenever I go into neutral and or come up to a full stop making my car turn off. It's not the battery or the alternator! Reading about it before, I a lot of people say it could be the MAP sensor? WTF is up with my ride? Has anyone had this problem before? How did you fix it? Thanks!
Old Nov 19, 2007 | 09:13 AM
ReddotsS2K's Avatar
Default Re: What is wrong with my Idle? Car turns OFF! (jdm j)
are u getting any check engine lights?
Old Nov 19, 2007 | 09:15 AM
jdm j's Avatar
Default Re: What is wrong with my Idle? Car turns OFF! (ReddotsS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">are u getting any check engine lights?
</TD></TR></TABLE>No CEL!
Old Nov 19, 2007 | 09:21 AM
LAS2K's Avatar
I would have said MAP sensor or fuel pump...but no CEL??
hrmphhh
Old Nov 19, 2007 | 10:25 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: What is wrong with my Idle? Car turns OFF! (LAS2K)
Under warranty?
Old Nov 19, 2007 | 04:42 PM
chunkotron's Avatar
bad map sensor or you're not downshifting (do you just coast to stops?)
check out this link:
http://www.s2ki.com/forums/ind...st=25
Old Nov 19, 2007 | 04:59 PM
ReddotsS2K's Avatar
i dont know what is wrong but i would be buying all new spark plugs and all thats jazz
Old Nov 19, 2007 | 05:13 PM
jdm j's Avatar
I usually coast, unless I'm about to stop from a high speed. Thanks for the helpful link! I was surprised how many people have had this problem! I have a MAP sensor to clean now and hope that everything gets fixed.
Old Nov 19, 2007 | 05:48 PM
Black S2K's Avatar
Yo hook it up with an update
Old Nov 19, 2007 | 08:05 PM
jdm j's Avatar
Default Re: (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">Yo hook it up with an update</TD></TR></TABLE>Fo Sho!
Old Nov 20, 2007 | 11:58 AM
i2ishift's Avatar
Default Re: (jdm j)
i vote for IACV or which ever system is used for the f20 motors. I use to be an Acura Tech and these use to see this go bad more than often. Symtoms also match.
Old Nov 20, 2007 | 04:26 PM
litoashunboai's Avatar
What's the mileage? try cleaning your throttle body and clean ur idle air control valve located on the throttle body, that may fix your problem.
Old Nov 20, 2007 | 04:28 PM
somtimes the piston in the iacv gets stuck, carburator cleaner should clean it out. if that doesn't fix ur problem you should replace the iacv, im confident its the problem.
Old Dec 5, 2007 | 02:59 PM
jdm j's Avatar
Default Throttle Body/Map Sensor Results!
So I take out my throttle body as well as the map sensor and clean them both. I put them both back on and wow..... I was impressed. I haven't had the problem since. Good looking out to all the people that help! "It did work!"
kenfu
Sep 16, 2008 04:15 PM
Stevegunit16
10
Feb 14, 2007 07:21 PM
dayyumm CYNTHIA
Jul 7, 2006 11:13 PM
EnzoSpeed
Apr 8, 2006 07:53 AM
LilCivic04
Jul 31, 2005 09:38 AM
