tps or map sensor problem? could it make my car slower?
Old Jul 30, 2005 | 08:20 PM
LilCivic04's Avatar
Default tps or map sensor problem? could it make my car slower?
i have a fully built d16z6 with a turbonetics t3/t4 turbo. when i first installed the turbo, the car was fast and had alot of torque. then one day all of a sudden the car gives a loopy idle and sometimes throw a random cel out of nowhere. so i just turn the car off and turn it back on it goes away. but after i had that lumpy idle, the car runs alot slower then it had before? anyone have any thoughts on this opinion? could it be a tps or map sensor problem?
Old Jul 30, 2005 | 09:06 PM
LilCivic04's Avatar
Default Re: tps or map sensor problem? could it make my car slower? (LilCivic04)
ttt someone must know
Old Jul 30, 2005 | 09:07 PM
95cxh22a's Avatar
check the codes and find out what it is.
Old Jul 30, 2005 | 10:36 PM
LilCivic04's Avatar
Default Re: tps or map sensor problem? could it make my car slower? (95cxh22a)
i just now did a cel check and i got code 7, which is tps sensor. so i disconnect the ecu and replug it back in and it went away. i turned the car on again and it ran the same. while i the car was at idle, i disconnect the map sensor and it killed the car. is that normal for a good working map sensor? i pluged it back in and turned on the car, this time i unplugged the tps sensor, and it had a really rough idle. it acted like it the car died for a second or two and came back to life again, it kept on doing that. is that normal also for a good working tps sensor?
Old Jul 30, 2005 | 10:45 PM
LilCivic04's Avatar
what would a bad tps sensor do?
Old Jul 30, 2005 | 11:40 PM
LilCivic04's Avatar
ttt
Old Jul 31, 2005 | 09:38 AM
LilCivic04's Avatar
ttt
HX35_Ek_Hatch
Jan 15, 2013 07:29 PM
Running925
Nov 14, 2006 07:57 AM
LilCivic04
Aug 1, 2005 11:09 PM
GQ 05YellowEVO8
Jul 12, 2001 09:23 AM
