Map sensor
Old Jan 15, 2007 | 11:05 PM
Stevegunit16's Avatar
Default Map sensor
What would be some signs of a bad map sensor, anybody???
Old Jan 15, 2007 | 11:23 PM
mikey-ej7's Avatar
Default Re: Map sensor (Stevegunit16)
I would think a high idle? Have you thought about spraying it with electrical cleaning spray?
Old Jan 16, 2007 | 01:26 AM
92ehatch's Avatar
Default Re: Map sensor (mikey-ej7)
with the check engine light on you would get i high idle, around 12 - 1300
without the check engine light on it idles around 500 - 600 and sounds horrible. runs really rich.
when accelerating...you pretty much dont accelerate, its jerky and stumbly and wont hardly move.
how do i know these things? cause mine just went bad yesterday code 3
Old Jan 16, 2007 | 03:27 AM
Syndacate's Avatar
Every time I unplugged the MAP sensor on my probe it stalled. Not sure if that's the difference between "unplugged" and "malfunctioning."
Old Feb 14, 2007 | 11:09 AM
Powered By Garrett's Avatar
Default Re: (Syndacate)
Back from the dead. I'm the new owner of this car.
The CEL light doesn't work, at all, like, it doesn't come on at KOEO or with the plug jumped. Is there any other way to check it?
Old Feb 14, 2007 | 11:33 AM
philosofy1's Avatar
Default Re: (Powered By Garrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered By Garrett &raquo;</TD></TR><TR><TD CLASS="quote">Back from the dead. I'm the new owner of this car.
The CEL light doesn't work, at all, like, it doesn't come on at KOEO or with the plug jumped. Is there any other way to check it?</TD></TR></TABLE>
have you replaced the bulb in the back of the cluster. try that first then try to read the code.
the common symptoms of a bad map sensor are running rich, hesitation, stalling. but there are other sensors that share the same or similar symptoms.
Old Feb 14, 2007 | 12:38 PM
Default Re: (philosofy1)
where can i get the correct bulb?
Old Feb 14, 2007 | 12:54 PM
philosofy1's Avatar
just go to your local part store, they have them. i don't remember the bulb size, but they're there. the store rep should be able to help. just remember to take the bulb out of the cluster first and bring it in.
Old Feb 14, 2007 | 07:18 PM
sql_civic's Avatar
Or take a known good bulb in the cluster and switch 'em.
Old Feb 14, 2007 | 07:20 PM
raphael's Avatar
a bad map **** up so many things like idle throotle response...one of the most important sensors mang
Old Feb 14, 2007 | 07:21 PM
raphael's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">have you replaced the bulb in the back of the cluster. try that first then try to read the code.
the common symptoms of a bad map sensor are running rich, hesitation, stalling. but there are other sensors that share the same or similar symptoms.</TD></TR></TABLE> AIR BENDING SHOW IS THE SHITZ
chucky86
Oct 13, 2011 02:46 PM
1993eghatch
Jun 24, 2010 03:25 PM
kenfu
Sep 16, 2008 04:15 PM
liftdhatch95
Dec 24, 2007 12:17 PM
del sol1658
13
Sep 20, 2006 03:15 PM
