CKF sensor question!!! quick question please help....
Old Nov 14, 2007 | 08:56 PM
boostedgsteg's Avatar
Default CKF sensor question!!! quick question please help....
OK ive got a 98 integra just swapped OBD2 H22 in, the h22 doesnt have a CKF sensor on the oil pump....im running an OBD1 ecu, do i need to do anything about the sensor? or am i fine without it?
Old Nov 14, 2007 | 09:55 PM
ekb16's Avatar
if the ecu doesnt look for that sensor then u will be fine
Old Nov 14, 2007 | 10:12 PM
Default Re: (ekb16)
awesome, thanks....im runnin a stock obd1 P13 now with a chipped p28 on the way so i should be fine
thanks again
Old Nov 15, 2007 | 04:52 AM
Runnerdown's Avatar
Default Re: (B16B_coupe)
That sensor is strictly for obd2 misfire detection. There is no disabling it on any ecu unless you connect the wires to the distributor (obd2 reasons). But if you have an obd1 ecu, then the sensor doesnt exist
turbo97coupe
Mar 31, 2009 07:44 PM
B18C_EJ8
Mar 6, 2006 10:41 AM
BB6-213
Oct 4, 2005 03:08 PM
CrazyKoreanCrx
Apr 20, 2004 10:25 AM
