Low Compression?
i just did a compression test and it got:
#1 - 135, 135
#2 - 140, 140
#3 - 130, 130
#4 - 135, 135
i pull the oil cap while its running and can feel the air a foot above the valve cover. time for a rebuild or a new JDM motor? what would be the better bet? its a 92 b16a
Modified by Frickr at 12:09 PM 11/11/2007
#1 - 135, 135
#2 - 140, 140
#3 - 130, 130
#4 - 135, 135
theres a hose connected to the intake. ill go back out in a little while and try it with a litle oil, its to damn cold to be sitting out there for an hour right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr »</TD></TR><TR><TD CLASS="quote">i just did a compression test and it got:
#1 - 135, 135
#2 - 140, 140
#3 - 130, 130
#4 - 135, 135
Modified by Frickr at 12:09 PM 11/11/2007</TD></TR></TABLE>
every compression tester is different, the thing to look at is the variance between cylinders
For Example,
#1 cyl=150
#2 cyl=145
#3 cyl=100
#4 cyl=150
you would then have a problem, with cylinder 3.
#1 - 135, 135
#2 - 140, 140
#3 - 130, 130
#4 - 135, 135
For Example,
#1 cyl=150
#2 cyl=145
#3 cyl=100
#4 cyl=150
peanuts8888
Jan 19, 2007 09:42 AM
