is a lil smoke sometimes from the pcv normal?
Old Aug 21, 2006 | 06:04 PM
97grnrs's Avatar
Default is a lil smoke sometimes from the pcv normal?
sometimes when its hot and i run car i see a small amount of smoke coming from the breather on the valve cover and also from the pcv valve (which i vent into atmosphere) .. is a lil normal or no? i did a comp test and it was 160-170 across all cyl.. i can smell the fumes from it sometimes
Old Aug 21, 2006 | 07:57 PM
Muckman's Avatar
Moderator in Chief
Default Re: is a lil smoke sometimes from the pcv normal? (97grnrs)
160-170 is kinda low. Whats your compression? Built motor or stock? Sounds like your getting some blow-by. Run a line from your pcv and valve cover to a coke bottle or something simple to catch any oil.
Old Aug 22, 2006 | 05:12 AM
97grnrs's Avatar
Default Re: is a lil smoke sometimes from the pcv normal? (Muckman)
stock ls. stock spec for compression is only like 180 ish my book says. it dont really blow any oil out.. just steam once in a while
Old Aug 22, 2006 | 09:04 AM
RyanEJ8's Avatar
It's normal to have a little blowby coming out the breather on a boosted Honda. Your compression does sound low though.
Old Aug 22, 2006 | 09:59 AM
adseguy's Avatar
Default Re: is a lil smoke sometimes from the pcv normal? (RyanEJ8)
an LS motor? 160-170 is fine...that's what mine ran and it never budged lower for 2 years. Gauges can be a little off too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Run a line from your pcv and valve cover to a coke bottle or something simple to catch any oil.</TD></TR></TABLE>
Do that and see if you have excess blow-by
Old Aug 22, 2006 | 10:55 AM
97grnrs's Avatar
Default Re: is a lil smoke sometimes from the pcv normal? (adseguy)
i did that.. no hardly nothing comes out but just lil puffs of whitish smoke once in a great while.
ganjasnack
May 21, 2008 11:22 AM
EK FLY
Apr 24, 2007 05:44 PM
peanuts8888
Jan 19, 2007 09:42 AM
servion
Mar 2, 2004 03:59 PM
ItzTw
Dec 14, 2003 07:10 AM
