Squeeling noise
Old Nov 10, 2007 | 07:11 PM
hitekper4mance's Avatar
Default Squeeling noise
Hello all. I've just gotten around to driving my car after I dont know how many months. When I start the car, it starts to make a high pitch squeel. I am thinking it is transmission related. When I drive it, the noise is still there but seems to go away with higher RPM. Or, the exhaust drowns it out. When I slow down, it comes back very prominent. So, when I am a a stop light, it sounds like its broken. Someone suggested it was my throwout bearing but... I have no clue. Hence, this is why I am posting here in the Tech section in hopes that someone with a like experience or expertise in this area will chime in. Thanks!!
Old Nov 11, 2007 | 08:04 PM
Default Re: Squeeling noise (hitekper4mance)
freakin sounds like the fan belt but its not. I think its coming from the tranny. I just dont want to rip it out again. especially if I have no idea what i am looking for. Anybody??
Old Nov 12, 2007 | 05:51 AM
Andrew77's Avatar
does it happen when the clutch is pressed in or let out? I have the same problem, a loud whine from the tranny. It happens when I let the clutch out and accelerate. Through research I found out it is most likely the input shaft bearing. Now I am just waiting on the parts so I can have fun rebuilding it.
Old Nov 12, 2007 | 08:47 AM
Default Re: Squeeling noise (Andrew77)
thanks for the reply. Mine is regardless. when I start the car, there is no noise. as soon as it warms up a little. there it goes. the clutch depressed will alter the sound just slightly but not significantly. When I drive the car, it usually goes away at higher rpm but never goes away.
Old Nov 12, 2007 | 09:25 AM
King V's Avatar
Try tensioning your alternator belt before you tear out your trans.
Old Nov 12, 2007 | 10:13 AM
Crazydave's Avatar
Default Re: Squeeling noise (King V)
Squeeling is usually a belt that need to be tightened or replaced. Buy your belts from NAPA
Old Nov 12, 2007 | 07:57 PM
Default Re: Squeeling noise (Crazydave)
i was told by .... of all places... my stereo shop... i know its not a mechanic but, they said it wasnt coming from the belt. Any tranny experts have a clue as to if this is something a transmission would do??
Old Nov 13, 2007 | 04:56 AM
King V's Avatar
First off, don't go put GM Synchromesh oil in your trans(try to figure out what it is first). I'm no trans pro, but I know bearings can make whatever noise they want if they're bad. My input shaft bearing howled like a wolf when it went bad(no ****).
Modified by King V at 9:12 AM 11/13/2007
Old Nov 13, 2007 | 06:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">First off, don't go put GM Synchromesh oil in your trans(try to figure out what it is first). I'm no trans pro, but I know bearings can make whatever noise they want if they're bad. My input shaft bearing howled like a wolf when it went bad(no ****).
Modified by King V at 9:12 AM 11/13/2007</TD></TR></TABLE>
Thanks King V. I think pulling my tranny would be the only logic. Unless I find a tranny expert that can help diagnose the problem. I am 99% sure its not a belt.
JDM215
Aug 30, 2010 05:34 PM
DaveSi677
Nov 4, 2008 07:18 AM
hyphenite
Honda Civic (2001 - 2005)
May 26, 2008 09:44 PM
fleaEG
Oct 18, 2007 02:34 PM
battleREADYb20
Oct 8, 2006 12:10 PM
