weird noise?
weird noise?
ok i just replaced the clutch throw out bearing and pressure plate on my b20 motor. its been a few weeks and everytime my car has sit over night and is cold. when i start it it makes a kinda wineing noise when its cold. and when it heats up it stops. i dunno what it is? it sound like its coming from the tranny but i dont know
yea. bought a whole clutch kit. it a kinda whiney noise. sound kinda like a belt noise but not as loud. the noise is only when i turn the car on. and when it warms up it goes away. i heard that it could be the slave cylynder not depressing all the way. when i changed the clutch i did have a problem getting pressure in it. lmk thanks
Re: (R.Kelley)
yeah, how exactly did you determine that it was coming from the tranny? did you stick your ear there? does it make the noise when the clutch is engaged or disengaged? or both? does it get louder/faster/higher pitched while you accelerate? common man, help us out.
Re: (Sleepy_Red_hatch)
yea i put my ear around ther and it sounded as if it was coming from there.i turn the car on and ill here it. its not in gear or no foot on the clutch either. and it does it. i rev the motor a bit and when it warms up it stops
Re: (battleREADYb20)
mine had something like that too, when i step on the clutch it goes away but once depress it comes back, mine never really went away when warm. I was playing around with the slave and the fork and when i go to grab the fort and pull it back it stops so i'm guessing it was the fork or slave cylinder that wasn't depressing all the way, I grease it a bit and now the sound is not there anymore, still don't know till this day exactly wat it is, but as of now since i grease the fork, sounds gone. Maybe someone can tell us what's wrong, Only think i can think of is that when i put my clutch back all together and rush thru it, I foegot to grease the release bearing so mayb it's da release bearing making the noise, not sure either.
well i was messing with it today. i turned the car on. went to the tranny listened. it kinda made a small whining noise. thien i moved the fork toward the driver side(im looking at the fron of the car) and it went away right then. then i let it out all the way and it made it again. then it started to go away. but it sound like i can steal her it very little. wheni put the clutch in theres a bearing that came with the kit. that i dodnt replace. it goes behind the flywheel i bealeve. the one one the car looked fine. i put some grease on it and some on the to bearing and put the tranny on. what could it be. thet slave cylender? could i have not blled it enough? of could it use a new one? lmk thanks
fleaEG
10-18-2007 02:34 PM
