Engine Removal
Sup VTEChnicians? I Got another question for you. I am removing a B18B1 out of my '94 Integra and I was wondering if I have to remove the Tranny with the engine or can I remove the engine just by itself.
I Figured it would be easier to remove just the engine insted of droppin them both. Cuz dont you have to remove the axles and all of that when you remove the tranny or what?? If I were to remove both what all would I need to remove and in which order?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">i agree with the other VTEChnicians</TD></TR></TABLE>
lol i love this kid...he is so brutal...
drop the engine out the bottom if possible...and do it as a whole. thats how i usually do it.
To remove the engine, you would first have to drop the transmission, which is a TOTAL and HUGE pain in the *** with the engine still in the car (I have done it twice, on my car and my brother's del Sol myself).
Either way, the axles have to come out. It's much, much MUCH easier to pull out both of them together.
Thanks everyone. I Got it out. I just took the engine out and it was pretty simple. Granted that I had the intake and exhaust manifolds off. I had the chains tenchioned on the cherry picker, loosended the bolts to the tranny, removed the engine mounts, took out the tranny bolts, and used two pry bars and seperated the two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugensports187 »</TD></TR><TR><TD CLASS="quote">Thanks everyone. I Got it out. I just took the engine out and it was pretty simple. Granted that I had the intake and exhaust manifolds off. I had the chains tenchioned on the cherry picker, loosended the bolts to the tranny, removed the engine mounts, took out the tranny bolts, and used two pry bars and seperated the two. </TD></TR></TABLE>
So you left the tranny still in the car? Dang that just seems like much more work. I know you had to remove the axles because you must have had to tilt the engine or tranny or both to get the tranny input shaft out of the clutch and flywheel.
crzy1208
Jan 23, 2013 03:03 PM
