BOOST + ATS final drive...
Old Jun 23, 2002 | 02:44 PM
uNF$@#!'s Avatar
Default BOOST + ATS final drive...
BOOST + ATS final drive = Insanity?
Old Jun 23, 2002 | 02:46 PM
hooptie157's Avatar
Default Re: BOOST + ATS final drive... (00-0187)
This equals no traction from 1st to 3d
[Modified by hooptie157, 3:46 PM 6/23/2002]
Old Jun 23, 2002 | 02:48 PM
Jason's Avatar
Default Re: BOOST + ATS final drive... (hooptie157)
depends on level of boost...but some NA cars have problems hooking up w/ the ATS w/ enough power
Old Jun 23, 2002 | 02:55 PM
TeamTooQuick's Avatar
Default Re: BOOST + ATS final drive... (Jason)
boost+ATS= No traction....
Old Jun 23, 2002 | 02:56 PM
Black R's Avatar
25 Year Member
.....it might be prudent to get the boost part running right and see how you like that. run the 1320 a few times and see if it meets your needs.
THEN, if you're feeling like it - try the ATS final... But it may be difficult to hook up on street tires...
Old Jun 23, 2002 | 03:06 PM
00-ITR-373's Avatar
Default Re: BOOST + ATS final drive... (Black R)
Toss in the ATS 3.077 First gear
+ ATS final.
[Modified by 00-ITR-373, 7:06 PM 6/23/2002]
Old Jul 6, 2002 | 11:09 PM
itr1244's Avatar
Default Re: BOOST + ATS final drive... (00-ITR-373)
but i think boosting cars have not much top end power compared to n/a and they usually make power at low end so i think not worth it
boost wants to rev lower
but not every cars
Old Jul 6, 2002 | 11:19 PM
Rob :190:'s Avatar
Default Re: BOOST + ATS final drive... (itr1244)
but not every cars
on our cars i disagree......yes FI does give good low end, but top end is where it shines...look at superchargers, the basic principle says the high the motor revs the more power it will make....
Old Jul 7, 2002 | 12:29 AM
uNF$@#!'s Avatar
thus you get the insane burnouts?
Old Jul 7, 2002 | 03:07 AM
Mr. Softee's Avatar
Default Re: BOOST + ATS final drive... (Soup ****)
itr1244 you clearly have no idea what boost lag is...i make jack **** for power until 4500 rpms
Old Jul 7, 2002 | 05:25 AM
ZygSpeed's Avatar
Default Re: BOOST + ATS final drive... (George Knighton)
I'm sure Zygspeed's going to do it, though. Just check w/him in a few weeks.
Actually, I'm looking at either a bigger turbo (T60) so as to still be "efficient" @ 9-9.5 K rpm, or GSR type gearing and a Kazz.
This weekend's research project.
btw -- what is the displacement of an ITR motor that's be changed from 10.6:1 to 9:1 by replacement of the pistons?
And while your at it ... the CFM at speeds of 4.5, 6, 7.5 and 9K rpm. TIA ed
[Modified by Zygspeed, 9:26 AM 7/7/2002]
Old Jul 7, 2002 | 07:01 AM
GRM Scott's Avatar
25 Year Member
Default Re: BOOST + ATS final drive... (Zygspeed)
BOOST + 4.929 FD = Rally car
Old Jul 7, 2002 | 07:12 AM
ZygSpeed's Avatar
Default Re: BOOST + ATS final drive... (Aleph)
Boost + 4.9 FD = no usable traction in any gear except with slicks on a drag strip.
The first question Steve (sgT) asked me is how much traction do you not want to have!?
It's also a top speed issue as I'd said above, at least for me.
Old Jul 7, 2002 | 07:23 AM
slowerthanu's Avatar
New User
Default Re: BOOST + ATS final drive... ( Rob)
but not every cars
true for a centrifugal blower, but not a positive displacement "roots" style blower.
Depending on how you sie the turbo, you may not have long eough gearing to build full boost in the first 2 gears. turbo motors generally appreciate taller gearing.
Old Jul 7, 2002 | 08:31 AM
FSTASNTZ's Avatar
Default Re: BOOST + ATS final drive... (slowerthanu)
Hence why most argue the LS tranny, with the lower final drive, is the better turbo tranny...
Jason
Old Jul 7, 2002 | 11:18 AM
FAST94GSR's Avatar
New User
Default Re: BOOST + ATS final drive... (94goldjungsr)
yea but once your spooled your 2nd 3rd and 4th shift will come so fast you wouldn't be able to shift fast enough. plus with boost you wouldn't want to hurt your top end, that's where it shines.
Old Jul 7, 2002 | 11:19 AM
FAST94GSR's Avatar
New User
Default Re: BOOST + ATS final drive... (FSTASNTZ)
Jason
The advantage of the LS tranny is the third gear, its so long and you can build up a lot of boost in that gear.
JS4KX
Sep 6, 2014 03:06 PM
EARLdaSQUIRREL
May 5, 2009 05:42 PM
Big O
Apr 18, 2004 10:05 PM
Big O
Apr 12, 2004 08:08 PM
ITR.00-1282
Dec 8, 2002 09:05 AM
