can you put ctr pistons in a gsr or would you use type r?
Old Nov 5, 2007 | 06:30 PM
DaYZeD.1's Avatar
Default can you put ctr pistons in a gsr or would you use type r?
im trying to find out if you can use the ctr piston in the gsr engine. or should i use type r pistons. also, if i change out the rod to a stronger one, would i get more torque? please i need this info...
Old Nov 5, 2007 | 08:01 PM
raphael's Avatar
Default Re: can you put ctr pistons in a gsr or would you use type r? (DaYZeD.1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaYZeD.1 &raquo;</TD></TR><TR><TD CLASS="quote">im trying to find out if you can use the ctr piston in the gsr engine. or should i use type r pistons. also, if i change out the rod to a stronger one, would i get more torque? please i need this info...</TD></TR></TABLE>reminds me of my young honda days...but anyways back to reality. ctr pistons like itr pistons will drop right in your gsr block. and aftermarket rods wont give more torque but will offer more durability in aggressive bottom-end builds. you will get more compression with ctr pistons than itr pistons.
Slickrick936
Feb 24, 2011 12:39 PM
GSR_hatch936
11
Jan 10, 2008 12:06 PM
k20ctr
18
Feb 17, 2006 07:58 AM
redvic
Jun 20, 2004 07:22 PM
slowdx
May 21, 2003 02:28 PM
