help on reading my check engine code?
Old Nov 4, 2007 | 01:46 PM
hondaon18's's Avatar
Default help on reading my check engine code?
okay so i jumped the plug and now the check engine flashes a code. it starts flashing 7 short times and one long one and then it flashes 7 short ones again. but i don't understand how to go about and read it. so can anyone explain to me cause im confused as hell. oh yeah i have a eg hatch with a b16a on a obd2 wiring and gsr obd2 ecu.
Old Nov 4, 2007 | 01:47 PM
t0p_sh0tta's Avatar
Default Re: help on reading my check engine code? (hondaon18's)
https://honda-tech.com/zerothread/1901557
If you're reading it right, it's the VSS (Code 17). Does your speedometer work properly?
The long blinks = the first number
The short blinks = the second number
Old Nov 5, 2007 | 11:36 AM
Default Re: help on reading my check engine code? (t0p_sh0tta)
yeah my speedometer works fine. what else can it be cause it blinks the 7 first and then the l long one second? can that mean that is misfire in cylinder one or does it have to blink seven one times for it to be the cylinder misfire
Old Nov 5, 2007 | 11:41 AM
BlueIntegraBoy's Avatar
7 TPS - throttle position sensor
10 IAT - intake air temperature sensor
Old Nov 5, 2007 | 11:49 AM
mckrank313's Avatar
Default Re: help on reading my check engine code? (BlueIntegraBoy)
what the guy said above me sounds like code 7 and 10
and since its the tps and iat you should be having some throttle response problems maybe a little idling problem
Old Nov 5, 2007 | 11:52 AM
okay so i have to codes that is what you are saying. i know that my tps sensor might be throwing a code cause i had to replace it and i didn't calibrate it yeah. but what about the intake air temperture sensor. i do have an idle problem. so it aint my cylinder 1 misfire right.
Old Nov 5, 2007 | 11:54 AM
Are you using an OBD1 engine harness and an OBD1-OBD2 jumper harness with ECU? If so, the OBD1 SOHC harness does not have an IAT.
Old Nov 5, 2007 | 11:55 AM
no obd 2 engine harness with obd 2 ecu. so it is my cylinder 1 misfire. but i do know that i have to cailbrate my tps cause i broke it and replaced it with out doing that calibration that you have to do
Old Nov 5, 2007 | 03:16 PM
TWINTECH93JDM's Avatar
CODES 7 AND 17
Old Nov 5, 2007 | 03:20 PM
civic08's Avatar
Default Re: help on reading my check engine code? (TWINTECH93JDM)
from what u just described, it would be 71 random misfire cylinder 1.. and then ur tps sensor too
tavo.760
Nov 12, 2013 12:32 AM
mikegeezy
Oct 3, 2006 05:42 PM
VTECyoda
Nov 17, 2003 07:25 AM
bumpin_bass
Dec 17, 2002 06:53 PM
JDMAllMota R731
Aug 12, 2002 09:12 AM
