need help with codes 52 and 45
ok so i swapped a b16a into my eg everything seems fine i have a p30 supposedly chipped which i doubt but the problem is that i have 2 codes
i have a code 52 since there is 5 fast and 2 slow then second is easy its code 45 since it says its running rich or lean but that i dont have a problem since i can fix but i have no idea what code 52 is any help would be appreciated
thanks in advance
thanks in advance
Re: need help with a code
**By counting the number of flashes, you can decipher the CEL code**
A LONG flash (1 second) is 10
A SHORT flash (0.5 second) is 1
For example, two long flashes followed quickly by two short flashes would be code 22. If there is more than one code, each code will be separated by a 2.5 second gap.
i have checked more than twice and that is the reason that im tripping about it it gives me 5 long flashes follwed by 2 short flashes and a pause and the second code
Yea i know i got mxed up reading the codes i know how to fix them i need a jdm tb gasket and my buddy made me one but didnt have a diagram so i need to make a a new one and the other one is the o2 sensor just havent had time cause of work again sorry and thanks for the fast input
eg crunkmonster
01-14-2004 03:29 AM
