dead end clip on obd2 cars
are you talkking in terms of which one to use for the resistor box? my mind reading powers expire tonight and im running low, if it is, it is the one with all the yellow with black tracers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inthad »</TD></TR><TR><TD CLASS="quote">so its the yellow wires with the black? </TD></TR></TABLE>
Yes, those are the ground wires for the injectors. ALWAYS check with a volt ohm meter if your not 100% sure
Check for continity between each injector yellow wire and the corresponding pin on the dead end clip. Remember with the plug in the dead end clip all the wire see ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">
they are 12v key on
</TD></TR></TABLE>they are 12v key on
T-RO
Feb 9, 2014 07:06 AM
RTW DC2R
May 16, 2006 05:57 PM
