Rear Lower Tie Bar - Finally got it mounted!!! Check it out!
Designed and made myself! With the help of my fellow machinest.
Just need to mount th sway-bar!
Can't belive the change already with just the new brace.
Tell me what ya think1
I might want to try that, I have access to a limited amount of machining tools. What did you use for a template? Its aluminum right? How thick? And I'm curious what sway bar you are useing too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing »</TD></TR><TR><TD CLASS="quote">
i know this is a bit of a stupid question but what is the difference between this and a sway bar dont they do about the same thing?</TD></TR></TABLE>
The brace acts as a reinforcement so you don't have tear out your subframe when you use a larger rear sway bar.
So, it stiffens up your rear end and prevents damaging your subframe.
what type of aluminum did you use?
also, would you be willing to pm me some dimensions for that, ive been wanting to make my own as well.
thanks if you can do that,
Aluminum is T-6061 - or Aircraft grade if that gets you excited. i won't say anything about a selling until i have mounted the sway-bar and can verify the whole thing works!
Now Availiable!!
https://honda-tech.com/zerothread?id=2139492
Modified by EG-Honda at 11:22 AM 11/1/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">Nice, that looks good, lol you cant really even see the "pmsuspension"</TD></TR></TABLE>
Yeah, but I would rather it hug the curve of the subframe then over hang it just for a place to put a logo (like some braces).
Cody08
May 1, 2018 09:28 AM
Rodzknight
Nov 18, 2006 05:08 PM
SCCAsean
Mar 23, 2006 12:14 AM
^Sammy]!.
Feb 7, 2004 08:15 AM
