Removing Stuck Head Stud???
How does one remove a stuck head stud? I'm swapping blocks, and when I pulled the head yesterday, one stud is stuck in the block..
I tried wrapping a towel around the middle of the stud and turning it with a pair of channel locks, but it won't budge...
Suggestions?
Suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">these are ARP studs, without the allen key hole in the top..
^ That **** makes me laugh. What you should do is thread on two nuts and jamb them together. Then merely put your box end on the nut closer to the head and hit the wrench to turn it. Don't try to reef on it to get it to turn, hitting it will give you more of an impact on the fastener and increase the chance of it busting loose.
skiracer8148
11
Aug 14, 2007 07:59 PM
