A little throttle body polishing
Old Oct 28, 2007 | 08:43 AM
CBURKE's Avatar
Default A little throttle body polishing
Not sure if this is where it goes, but just thought I would share.
Now, I do this for friends and my self, not sure if it really does anything. On the butt Dino I feel better response and smother idle.
Here are some pics
Started by cleaning it up and bit and painting it
then wire wheeled the butterfly and sand it with 120,220,320,400,600.
Now time for the inside
I do the same sanding process, but I like to curve the edges a bit.
That's all thanks for looking, and if this is in the wrong forum please move it.
Old Oct 28, 2007 | 11:17 AM
raleylund's Avatar
Default Re: A little throttle body polishing (CBURKE)
i doubt it really does anything, but sure does look pretty... good for shows i guess.
Old Oct 28, 2007 | 11:45 AM
CBURKE's Avatar
Well I was thinking it's going to make the air go through smother, kinda like when you t-body is really dirty and you clean it the car runs better.
Old Oct 29, 2007 | 04:31 AM
savestheday's Avatar
Default Re: (CBURKE)
Very shiny. You gain the most in throttle body flow by making the shaft and the bolt heads thinner, but normally make it to where you can't take it apart again.
Old Oct 30, 2007 | 06:11 AM
riceisnicenv's Avatar
Default Re: (savestheday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raleylund &raquo;</TD></TR><TR><TD CLASS="quote">i doubt it really does anything, but sure does look pretty... good for shows i guess.</TD></TR></TABLE>
It could be beneficial at wide open throttle, where the air flows over the (now polished) surface. The shaft the butterfly plate attaches to is a huge obstruction. I think if that could be relocated to the other side of the plate you would see part throttle response and power increase. I don't know if anybody has tried this but it makes sense
Old Oct 30, 2007 | 10:49 AM
CBURKE's Avatar
I was thinking it didn't hut it anyway to try.
Old Oct 30, 2007 | 04:35 PM
codenamezero's Avatar
polished surface actually creates more turbulance
Old Oct 30, 2007 | 04:44 PM
91jdmhatchback's Avatar
Default Re: (codenamezero)
doesn't a slightly rough surface create low pressure spots on the surface which speeds up the air moving over top of it? kinda like why you don't want to polish the intake ports on a cylinder head?
i could be totally wrong on this but i thought that is what i read.
Old Oct 30, 2007 | 06:57 PM
http://www.team-integra.net/se...eID=9
Old Oct 30, 2007 | 10:17 PM
Good article codenamezero... do you know what roughness coefficient is too smooth?
Old Oct 31, 2007 | 08:21 PM
k24em2's Avatar
Default Re: (riceisnicenv)
I wonder if anyone has every taken the time to dimple out the whole intake manifold and throttle like a golf ball
Old Nov 3, 2007 | 12:39 PM
mike93eh2's Avatar
Default Re: (91jdmhatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">doesn't a slightly rough surface create low pressure spots on the surface which speeds up the air moving over top of it? kinda like why you don't want to polish the intake ports on a cylinder head?
you dont polish the intake ports on a head because fuel doesnt like to atomize on a polished surface.
Old Nov 6, 2007 | 11:58 AM
driveahonda's Avatar
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if anyone has every taken the time to dimple out the whole intake manifold and throttle like a golf ball</TD></TR></TABLE>
hehe
Old Nov 6, 2007 | 12:40 PM
95 integra's Avatar
Default Re: (driveahonda)
That throttle plate looks nice and shiney. Good job on that
Old Nov 6, 2007 | 05:00 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
put the throttle plate on a chain, wear it around your neck, and call it a day.
baulin!
Old Nov 7, 2007 | 04:37 AM
OP,
Bring that thing and a stocker to a flowbench, see how it does.
Old Nov 8, 2007 | 04:58 AM
CBURKE's Avatar
I would have I had the ability to do so, because it seems anything you do to your car make it work in your head.
SPD DMN
Apr 17, 2008 12:19 AM
95_red_dc
Sep 11, 2006 09:47 PM
ITRacer121
42
Mar 20, 2003 02:53 PM
JDMvtecDRAGSTA
Jun 28, 2002 08:35 PM
luc_cairo
May 2, 2002 06:33 PM
