having driver side axle seal problems. LS hydro tanny
Old Oct 25, 2007 | 02:58 PM
doodooheadfart's Avatar
Default having driver side axle seal problems. LS hydro tanny
my transmission is leaking from the driver side axle seal. i noticed that there is a lip where the seal rides on the intermediate shaft and i have been trying to align the seal with the lip. i have repositioned the seal at least 3 different times now and have replaced the seal once.
if that sounded too confusing heres some pictures:
here is the lip that im talking about on the intermediate shaft
the inside diameter of the seal has a V shaped lip that i think runs on the axle's lip
heres how it looks with the shaft inside the transmission
Old Oct 26, 2007 | 07:53 AM
Default Re: having driver side axle seal problems. LS hydro tanny (doodooheadfart)
any thoughts at all would be great fellas
im lost here, i replaced the seal and put some lucas stop leak/ transmission fix in it. and shes still leakin. i never knew that the seal had to be seated in a certain postion, but apparently it does...
like i said ive tried 3 different depth at which the seal sits in the bore and every time it's leaked. and i replaced the seal the first time...
***!!BUMP!!***
Old Oct 27, 2007 | 08:20 AM
*bump*
Old Oct 27, 2007 | 08:32 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: (doodooheadfart)
All I can say is that when I did the seals on my Y21 I put them in as deep as they could go and they don't leak a drop.
From what vehicle/year is your intermediate shaft from?
Old Oct 27, 2007 | 03:47 PM
Jared's Avatar
looks like an aftermarket seal, and they could have given you the 90-93 teg seal which is 5mm bigger ID and will leak like you describe
Old Oct 28, 2007 | 06:31 AM
Chiovnidca's Avatar
Default Re: (Jared)
The seal should be set deeper. Flush with the case is about right.
Old Oct 30, 2007 | 11:17 AM
i already tried installing it flush
i'll pull it tomorrow and compare it to other sizes
though the last time i had it out i put it on the intermediate shaft and seemed pretty snug
Old Nov 12, 2007 | 08:13 AM
yeah i tried a couple of different sizes and grab the one that was the most snug
i installed it in just a little bit more than flush and now it is not leaking at all
thanks fellazzz
Old Nov 12, 2007 | 12:02 PM
Mista Bone's Avatar
D Tranny Guru
get a seal from HONDA, not that POS.
Honda seal, outer edge flush with the case
for example
Iloveyourhonda92
May 13, 2012 09:29 PM
kdsmonitor
Mar 7, 2009 04:00 PM
itsLOUiSduh
Oct 17, 2008 12:31 PM
doublethink
Oct 10, 2004 06:57 PM
Pele
Jul 31, 2003 06:32 AM
