OBD2B SWAP IN 95 EG8???
You don't need any jumper, and you should not use the OBD2 ecu. Find yourself an OBD1 P72 which plugs directly into your harness and you only need to add the knock sensor and IAB wires. If you try using the OBD2 ecu you will have to face the immobilizer, crank flux sensor, and add a secondary O2 sensor. Difficult and totally pointless.
screen_name
Apr 22, 2006 06:56 PM
