OBD2B SWAP IN 95 EG8???
hey guys i have a full OBD2B GSR swap the swap came with a OBD2"A" P72 "JUMPER" so i was try to find out what all i need to do in swap it in my EG
You don't need any jumper, and you should not use the OBD2 ecu. Find yourself an OBD1 P72 which plugs directly into your harness and you only need to add the knock sensor and IAB wires. If you try using the OBD2 ecu you will have to face the immobilizer, crank flux sensor, and add a secondary O2 sensor. Difficult and totally pointless.
Everyone who is OBD2 is always trying to convert back to OBD1 ecu's, take advantage of being OBD1 already and not needed to buy converters or anything.
screen_name
04-22-2006 06:56 PM
