98 civic dx with B16a *help wiring vtec*
Old Oct 23, 2007 | 09:56 AM
ZUL8R's Avatar
Default 98 civic dx with B16a *help wiring vtec*
So we got the motor and trans in and now i need vtec. I have the P28 that i used with my single cam motor on this setup. I need to know where to put my vtec wire and pressure wire? where can i find a diagram?
The motor is from a 2000 civic Si and i had a D16y7. It has the OBD1 conv harness and the P28. the program is crome and its just a basic tune. I plan on going hondata route and heading to the dyno soon so i wanna get that vtec hooked up.
Thanks guys!!!
Old Oct 23, 2007 | 10:13 AM
Eran's Avatar
HT White Ops
You should be wiring VTEC to the conversion harness, not the ECU. When you're using a conversion harness, you treat it like it's the stock plug.
Here's a diagram to help you out:
OBD2A Pinout --
Old Oct 24, 2007 | 06:25 AM
ZUL8R's Avatar
Default Re: (Eran)
where the wires are suppose to go into the harness is empty. where can i get the little connectors?
Old Oct 24, 2007 | 11:21 AM
B20Monster's Avatar
Default Re: (ZUL8R)
if you have a junkyard nearby, go in there an snip the ecu connector plugs off any ek. either that, hope you got a spare junk harness.. dont forget to relocate the IAC pinouts
Modified by B20Monster at 12:39 PM 10/24/2007
Old Oct 24, 2007 | 11:37 AM
88rexA6's Avatar
Default Re: (B20Monster)
obd1 and obd0 harnesses use those pins as well. also, some random plugs may use it. depin some male plugs you may have laying around and see if those pins fit.
Old Oct 24, 2007 | 11:48 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R &raquo;</TD></TR><TR><TD CLASS="quote">So we got the motor and trans in and now i need vtec. I have the P28 that i used with my single cam motor on this setup. I need to know where to put my vtec wire and pressure wire? where can i find a diagram?
Thanks guys!!!
eran already has posted a diagram, but i hope the links i have provide help just as much if not more!
this is for wire removal from the harness.
http://www.ff-squad.com/tech/w...l.jpg
shock tower
http://www.ff-squad.com/tech/w...g.jpg
VTEC wiring (ECU pinouts)
http://www.ff-squad.com/tech/w...5.jpg
Old Oct 24, 2007 | 12:34 PM
ZUL8R's Avatar
Default Re: (philosofy1)
Thanks Guys!!! I'll get started
heres the old setup
And the new setup
SAy BYE
Modified by ZUL8R at 4:45 PM 10/24/2007
Modified by ZUL8R at 4:46 PM 10/24/2007
Bulli Kid
Jun 11, 2007 03:17 PM
Macleod95Civic
Nov 3, 2004 08:54 AM
XzzYzzX
Jan 19, 2004 09:46 PM
AngelTeg
Aug 24, 2003 07:03 PM
Baggy Spandex
11
Jul 27, 2003 08:37 PM
