Best tranny for my LS?
Old Oct 17, 2007 | 11:09 PM
Knucklehead7's Avatar
Default Best tranny for my LS? ::
Ok I have a 95' Acura Integra LS Special Edition....would like to know which would be the better tranny the LS,GSR, or Si.....track and highway runs. I now have a Y80 tranny!!!
and YES I do plan on boosting it AFTER building the motor!!!
Modified by Knucklehead7 at 6:54 AM 10/18/2007
Old Oct 17, 2007 | 11:13 PM
davidluko's Avatar
The b16 tranny is the best out of the 3 because it has the shortest gearing (it's exactly like the ITR tranny but without the LSD that the ITR has). Of course, then the top speed is lower and your RPMs will be pretty high on the freeway, so you can swap in an LS fifth gear for the best of both worlds.
Old Oct 18, 2007 | 05:08 AM
posHonda's Avatar
b16 tranny and get one with LSD if you can. Thatll run you close to $1k though.
Old Oct 18, 2007 | 05:48 AM
LordAphotic's Avatar
honestly the gearing for the b16 is wayy too agressive for the ls low rpms...
I had a type r tranny on my ls and then b20 engine.... it was a lot of fun but honestly in the long run ull be better off with a gsr tranny... get one with lsd if u can afford it they cost around 900$.
Honestly u will enjoy the b16 tranny cause u think your car will have gotten super fast... but then when u get passed up by an ls with gsr tranny and minor mods u wont be as happy...
if u drive on the freeway a lot u wont like the small gear ratios either... unless u swap out the 5th gear.....
the ls engine DOES NOT like to be in high rpms often... the rod ratio is absolutely aweful and puts a lot of stress on the sides of the cylinder walls when pushing up. the b16 and itr have almost perfect ratios which put almost no presure on the walls allowing them to rev higher and last longer.... the gsr has a good ratio but not as good as the itr or b16.
simply put... unless ur gona ls vtec or do something thats gona push your powerband up into higher rpms the itr or b16 tranny is not a good idea and you should stick to the gsr tranny....
but it all depends on your goals and your ability to be real with yourself and not drool over reaching the redline almost instantly but getting very little speed in the exhange.... to give u an idea of how small the b16 itr 5th gear is... its smaller than the LS 4th gear. so drive around with your 4th gear and picture the rpms a little higher than where they are and thats what your 5th gear will be like...
1st and 2nd gear are the same on all the tranies... just different final drive ratios.
3rd - 5th /lsd/final drive ratios is what makes them differnet.
Old Oct 18, 2007 | 05:52 AM
Default Re: (Hatch_R)
Alright Hatch_R you say that the Si tranny is best because it revs better and I'll get to the point I want quicker which yes is good but mostly only for track. Now if I'm wrong correct me but wouldn't the Si tranny be my down fall on the Highway, and what's the lowest gear I'll probably be able to get into at about a 60-70 freeway roll?
Another thing I have a SE and my tranny is a Y-80 are the Y-80's the GSR tranny or not I've heard different stories?
Old Oct 18, 2007 | 10:55 AM
stp_vtec_boi's Avatar
Default Re: (Knucklehead7)
gs-r is the way to go i've seen it and its fast... stop & go and highway you just gotta put some power for the top end and your fast...
Old Oct 18, 2007 | 11:01 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (stp_vtec_boi)
pretty sure its a ls tranny http://www.ff-squad.com/tech/temp/Bgears.htm
Also, a b16/si tranny is probably your best bet, you might be able to drop it down to 3rd at 60 I cant remember it was a long time ago when I had the setup.
Old Oct 18, 2007 | 11:03 AM
posHonda's Avatar
Default Re: (LordAphotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">
3rd - 5th /lsd/final drive ratios is what makes them differnet.</TD></TR></TABLE>
gsr and ls 1st-2nd are the same but the gsr is shorter from 3-5.
a b16/itr tranny has shorter gears from 2-5.
all B series 1st gear is the same though
Old Oct 19, 2007 | 06:51 PM
davidluko's Avatar
^Don't forget about the difference in final drives. Even between GSR 1st and LS 1st gears there is a slight difference because of the final drive. And yes, the Si tranny will be quicker in acceleration but will have a lower top speed. Check this out... http://www.fatboyraceworks.com/gears/ At 60mph you'll be able to drop it into 3rd.
Old Oct 19, 2007 | 08:12 PM
Funkin Flux's Avatar
keep your ls tranny and swap in a b16 3rd gear and JDM Type R final drive
Old Oct 19, 2007 | 08:53 PM
SIC_jdm_da9's Avatar
get a b16 tranny and slap the LS 5th gear in.....
Old Oct 20, 2007 | 12:07 AM
Default Re: (SIC_jdm_da9)
well all of you guys have been helpful and yeah I actually have thought about swaping either my 3rd or 4th...or maybe even both with the b16/si but wouldn't that lower my topend?? All I know is that my 2nd gear pulls like a mother and 3rd isn't that bad either!!!
Also I'm going for a built LS-T that's why I'm asking for tranny info to find out who's actually ran that setup and what were the results of it???
Old Oct 20, 2007 | 10:55 AM
swapping in a 3rd gear will only change your 3rd gear ratio If you swap in a different final drive it will then affect your overall top speed
Old Oct 20, 2007 | 11:05 AM
yc_dc4mar's Avatar
my friend had b16 tranny on his ls with nos. it was dope fast! but if your going to boost it then gsr imo or ls tranny for boost is good. im getting a gsr tanny for my ls.
Old Oct 20, 2007 | 11:09 AM
yc_dc4mar's Avatar
seriously though b16 is not good for boost. horrible for boost. i dont care what anyone says. unless you have lsd
Old Oct 20, 2007 | 03:17 PM
iluvmydc4's Avatar
ls tranny = any boosted b series....
Old Oct 20, 2007 | 03:51 PM
Dartanian's Avatar
Default Re: (iluvmydc4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yc_dc4mar &raquo;</TD></TR><TR><TD CLASS="quote">seriously though b16 is not good for boost. horrible for boost. i dont care what anyone says. unless you have lsd </TD></TR></TABLE>
You have absolutely no idea what you are talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmydc4 &raquo;</TD></TR><TR><TD CLASS="quote">ls tranny = any boosted b series....</TD></TR></TABLE>
Oh god. I knew some tard would try and say the LS tranny is better for boost.
The LS transmission is pathetic on any application.
Old Oct 20, 2007 | 04:17 PM
SleeperGSR's Avatar
Default Re: (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">
The LS transmission is pathetic on any application.</TD></TR></TABLE>
I don't agree with this for 2 reasons.
1. Give me an unlimited budget and a car could be designed to perform with the ls transmission gear ratios.
2. For people on a budget they could build a car that is fun without having to swap the tranny. money could be put into other places to make the car fun to drive, not necessairly the fastest in the world.
It is one variable out of thousands someone needs to think about when building a car. If your going to keep the ls tranny then you will need to build the engine torque curve around your gear ratios so it can perform better than it did stock. If you are going to swap it out, go for that also. The longer gears can be beniffical on a road course, shifting takes time.
Old Oct 20, 2007 | 10:25 PM
Dartanian's Avatar
Default Re: (SleeperGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">
It is one variable out of thousands someone needs to think about when building a car. If your going to keep the ls tranny then you will need to build the engine torque curve around your gear ratios so it can perform better than it did stock. If you are going to swap it out, go for that also. The longer gears can be beniffical on a road course, shifting takes time. </TD></TR></TABLE>
That same setup built around the LS transmission would be seriously woken up if a GSR or B16 transmission were swapped in. Longer gears will be a disadvantage for most people. I highly doubt many of us get on a road course where we can wind it out to 150 on the straights. Shorter gears will always accelerate faster because you will get through the powerband faster. The only time that is a disadvantage is if you are trapping fast enough that you are shifting into 5th before the finish.
Old Oct 21, 2007 | 04:33 AM
SleeperGSR's Avatar
That same setup built around the LS transmission would be seriously woken up if a GSR or B16 transmission were swapped in. Longer gears will be a disadvantage for most people. I highly doubt many of us get on a road course where we can wind it out to 150 on the straights. Shorter gears will always accelerate faster because you will get through the powerband faster. The only time that is a disadvantage is if you are trapping fast enough that you are shifting into 5th before the finish.</TD></TR></TABLE>
I didn't say anything about top speed... You're not understaning what i'm saying, youre just set on telling me things you have heard other people say. Some driving is about momentum and not acceleration, in which case the ls transmision may be benificial. I'm not saying that it is better, just trying to point out maybe something positive about it. Gear ratios are changed on race cars for every track, there may be one track out there in the world that the ls tranny is geared idealy for.
Old Oct 21, 2007 | 09:13 AM
Dartanian's Avatar
I didn't say anything about top speed... </TD></TR></TABLE>
Ok, I did. That is the only thing the LS transmission has going for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">You're not understaning what i'm saying</TD></TR></TABLE>
You don't understand what you are saying...of course I don't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">youre just set on telling me things you have heard other people say.</TD></TR></TABLE>
I have experience with all three transmissions. The shorter geared always accelerated faster. Faster accelerate means faster trap speeds at a drag strip and quicker exits out of corners on the track.
I have yet to see evidence to prove your point since you have so much "experience", whatever your point was...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">Some driving is about momentum and not acceleration, in which case the ls transmision may be benificial. I'm not saying that it is better, just trying to point out maybe something positive about it. </TD></TR></TABLE>
WTF does momentum have to do with gear ratios and this conversation? Nothing.
I like the complete contradiction a sentence later. Didn't you just contradict the whole reason you are posting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">Gear ratios are changed on race cars for every track</TD></TR></TABLE>
Since when were we talking about race cars? Race cars can swap in custom gear sets to suit their needs, so this is completely irrelevant to the discussion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">there may be one track out there in the world that the ls tranny is geared idealy for. </TD></TR></TABLE>
Doubt it.
Old Oct 21, 2007 | 09:53 AM
SleeperGSR's Avatar
1.I have experience with all three transmissions. The shorter geared always accelerated faster. Faster accelerate means faster trap speeds at a drag strip and quicker exits out of corners on the track.
2.I have yet to see evidence to prove your point since you have so much "experience", whatever your point was...
3.WTF does momentum have to do with gear ratios and this conversation? Nothing.
4.I like the complete contradiction a sentence later. Didn't you just contradict the whole reason you are posting?
5.Since when were we talking about race cars? Race cars can swap in custom gear sets to suit their needs, so this is completely irrelevant to the discussion.
1. No one told me you were so cool
2. I never claimed to be an expert just trying to get some different input
3. You have never driven on a track
4. if you say so
5. trying to make a point about selecting gear ratios
keep on truckin man!
Old Oct 21, 2007 | 09:58 AM
hack_tc's Avatar
GSR w/LS 5th
Old Oct 21, 2007 | 10:45 AM
Dartanian's Avatar
4. if you say so
keep on truckin man! </TD></TR></TABLE>
1. No one told me I was so cool, either.
2. Then you wouldn't have contradicted me with an argument that you couldn't show any solid evidence to prove. You would have asked a question instead.
3. Whatever you say, dude. Judging by your rebuttals, I would say you were 16 or 17 and that would give me more track time than you have ever had behind the wheel.
4. I do.
5. You had no point. It was irrelevant.
dpine
Oct 1, 2007 09:59 AM
Rod.
Sep 23, 2004 02:45 PM
94lsboost
Sep 21, 2003 03:30 PM
p1ccoloz
May 6, 2003 01:02 AM
Turbo_Teg
Nov 14, 2002 09:37 PM
