knock sensor question..
Old Oct 17, 2007 | 07:45 PM
vyboi's Avatar
Default which intake manifold to use
I got a 95 Del sol S that i just dropped in a 2000 d16y8 vtec motor and was wondering if I needed to add the knock sensor in D3 on my p28 ecu. It's currently not throwing a check engine light. I got the answer i needed and thanks guys for the info..
I GOT ONE MORE QUESTION THE SAME MOTOR SETUP .. CURRENTLY I'M USING A
B15B7 INTAKE MANIFOLD... SO WILL USING A 92-95 EX INTAKE MANIFOLD MAKE A BIG DIFFERENCE? KEEP IN MIND THAT I'M USING THE 92-95 INTAKE MANIFOLD TO KEEP THE IAVC AND TEMP SENSORS AND PLUGS TO MATCH UP WITH THE EX ENGINE HARNESS.
Modified by vyboi at 9:30 PM 10/17/2007
Old Oct 17, 2007 | 08:02 PM
numberone's Avatar
Default Re: knock sensor question.. (vyboi)
No
Old Oct 17, 2007 | 08:08 PM
egsleepercivic's Avatar
obd1 p28 doesn't look for knock sensor
Old Oct 17, 2007 | 08:21 PM
vyboi's Avatar
Default Re: (egsleepercivic)
thanks peeps.... i've been searching all over and found no luck
B_Swapped93
Jan 15, 2013 04:28 PM
92'si
Feb 8, 2010 06:27 PM
vyboi
Oct 17, 2007 09:51 PM
lv6l
Jan 2, 2005 05:55 PM
VTECLuDe96
Dec 22, 2004 09:31 PM
