knock sensor question..
which intake manifold to use
I got a 95 Del sol S that i just dropped in a 2000 d16y8 vtec motor and was wondering if I needed to add the knock sensor in D3 on my p28 ecu. It's currently not throwing a check engine light. I got the answer i needed and thanks guys for the info..
I GOT ONE MORE QUESTION THE SAME MOTOR SETUP .. CURRENTLY I'M USING A
B15B7 INTAKE MANIFOLD... SO WILL USING A 92-95 EX INTAKE MANIFOLD MAKE A BIG DIFFERENCE? KEEP IN MIND THAT I'M USING THE 92-95 INTAKE MANIFOLD TO KEEP THE IAVC AND TEMP SENSORS AND PLUGS TO MATCH UP WITH THE EX ENGINE HARNESS.
Modified by vyboi at 9:30 PM 10/17/2007
