BONE STOCK b18c 379whp @ 14psi 100oc pump gas tuned via Supr Dave
Old Oct 16, 2007 | 09:24 PM
Ls1 FD3s's Avatar
Default BONE STOCK b18c 379whp @ 14psi 100oc pump gas tuned via Supr Dave
Supr Dave @ Whip Factory proves himself the man once again pushing the limits of my 100% OEM stock internalled 97 US spec b18c1 with 379WHP @ 14psi on pump 100 octaine! Off the WG spring, the tune is set for 9psi which netted 315whp for 93 octaine daily driver use. I drive this car everywhere, true story!
The graph:
The build:
130k mile OEM stock 97 US b18c1 with ARP headstuds (only non OEM internal mod)
00 spec ITR cams
LS trans with GSR ring/pinion and ITR LSD
Slowmotion Ind. ramhorn
GT40 "blowzilla"
.70 a/r on a .63 a/r t3 hotside
2.5" piping
OBX intercooler (i make that **** work baby!)
hondata Tuned via the Supr Dave @ whip factory
1000cc injectors
3" DP
MSD pro billet dizzy with 6al and digital 2-step
I will be starting a thread in the drag racing forum. Can you say 10 second car on pump gas on a drag radial??? I can, il be making the thread next with a link to be added in here. CHEERS!
Link to drag racing forum:
https://honda-tech.com/zerothread/2127643
Modified by Ls1 FD3s at 10:49 PM 10/16/2007
Old Oct 16, 2007 | 09:48 PM
boosted_17's Avatar
Default Re: BONE STOCK b18c 379whp @ 14psi 100oc pump gas tuned via Supr Dave (Ls1 FD3s)
nice numbers
Old Oct 16, 2007 | 09:49 PM
Ls1 FD3s's Avatar
Link to the drag racing forum for the ET!
Old Oct 17, 2007 | 02:32 PM
Ls1 FD3s's Avatar
30mpg too when cruising, heh.
Old Oct 17, 2007 | 05:06 PM
mrbsponge's Avatar
very nice i have done extremely similar numbers BUT with an LS motor, no vtec! 93octane
dave does really good work
Old Oct 21, 2007 | 12:36 AM
Ls1 FD3s's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">very nice i have done extremely similar numbers BUT with an LS motor, no vtec! 93octane
dave does really good work</TD></TR></TABLE>
no love for the Veee-tech? hahah, HP is HP and ET is an ET dont matter how you get it done!
props to dave for sure!
Old Oct 21, 2007 | 08:19 AM
Shaun's Avatar
Old Oct 21, 2007 | 10:18 AM
MidwestAutoWorks's Avatar
Default Re: (Shaun)
Did he actually pull the plugs and check them while tuning?
Also, he actually gave you a dyno sheet?
Im still waiting on mine from months ago.
Old Oct 21, 2007 | 11:06 AM
chubz0r's Avatar
Default Re: (MidwestAutoWorks)
incredible numbers man... dave does it again
btw, nice times and driving!
Old Oct 21, 2007 | 12:47 PM
Ls1 FD3s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chubz0r &raquo;</TD></TR><TR><TD CLASS="quote">incredible numbers man... dave does it again
btw, nice times and driving!</TD></TR></TABLE>
thanks man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">Did he actually pull the plugs and check them while tuning?
Also, he actually gave you a dyno sheet? </TD></TR></TABLE>
Yes he pulled plugs, he emailed me the dyno graph, the printer wasnt working.
Old Oct 21, 2007 | 01:52 PM
Default Re: (Ls1 FD3s)
O sweet good for you.
He never check my plugs and it was a boosted s2000 motor.
He ended up cracking a ring from detontaion and scored a cylinder wall, on top of that he still charged me.
Old Oct 21, 2007 | 02:24 PM
alpha's Avatar
Great results on the dyno and at the track!
Old Oct 21, 2007 | 03:48 PM
Ls1 FD3s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">O sweet good for you.
He ended up cracking a ring from detontaion and scored a cylinder wall, on top of that he still charged me. </TD></TR></TABLE>
Well i am sorry to hear that, but ive never heard of a failure under dave's name and i honestly think it wasnt the tuner's fault for the catastrophy.
Old Oct 21, 2007 | 03:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">
Well i am sorry to hear that, but ive never heard of a failure under dave's name and i honestly think it wasnt the tuner's fault for the catastrophy. </TD></TR></TABLE>
It was 100 percent his fault.
1. He never checked my plugs
2. I dont think he knows wtf he is doing with aem ems.
3. He was installing AEM software when I pulled up.
This is the third failure Ive heard under dave... 2 others were blown headgakets.
Old Oct 21, 2007 | 03:59 PM
Ls1 FD3s's Avatar
This is the third failure Ive heard under dave... 2 others were blown headgakets.</TD></TR></TABLE>
blown headgaskets cannot be blamed on the tuner, like i said, probably wasnt the tuner's fault. I have seen way tooo many poorly put together cars. It is your job to check plug gaps/plug heat range prior to arriving at the dyno. As we ALL know honda engines were designed N/a, in thoery its your fault for putting the turbo on, lol just ******* with ya!
Case and point is my threads i created based on my experiences with Dave. Nothing but good work, skillful tuning, and reliable tunes with exceedingly high WHP numbers on a stock b18c. Granted he normally would NOT tune for that much WHP on anyone elses stock engine due to keeping it under the danger zone of the stock engine's limits. I insisted we make the 380, it was my goal, he made it happen succesfully.
Old Oct 21, 2007 | 04:16 PM
SC61HB's Avatar
Lets keep this on topic!
Great numbers and to Dave!!
Modified by SC61HB at 7:58 PM 10/21/2007
garage16.ca
Feb 24, 2009 11:04 AM
garage16.ca
Jul 21, 2008 01:21 PM
nexxxt
Apr 14, 2007 12:41 AM
X2BOARD
Jun 12, 2004 06:55 PM
Nextelbuddy
May 31, 2004 01:59 AM
