I'm stupid... How much WHP with OEM GSR fuel pump ?
I couldn't filter the search enough... so I resort to asking this one.
How much whp will an OEM GSR/ITR/B16 fuel pump support ?
Or if you have the formula or something...
Thanx
Thanx
Re: I'm stupid... How much WHP with OEM GSR fuel pump ? (b16ahybrid)
Also, I would run a 440 or so injector.
just trying to figure it out... I am running a stock DX pump now and it needs to be replaced BAD.
I plan on making about ~200whp and about 50 more on spray (in the future)
So anyone else ? stock dohc vtec pump with 440 injectors... should I upgrade ?
Re: (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD »</TD></TR><TR><TD CLASS="quote">250whp from a stock pump...wow...
so I think I may need to go walboro... damn... I was trying to save a couple bucks.</TD></TR></TABLE>
If thats all your trying to do (save a few bucks) I wouldn't try saving there.
I've seen 300whp out of stock pumps (gs-r's running 550cc+ injectors) but if we're talking the difference between buying another stock pump and buying a walbro, spend the extra $40 and get a pump that you KNOW is going to flow more then enough.
buy a couple home depot rubber couplers instead of silicon couplers if your looking to save a few bucks.
Re: (hpfsi)
Hmmm....
chart is good... thanks fo the info so far guys.
I plan to run stock fuel pressure prolly. I am n/a, but will add nitrous sometime in the future. Going to upgrade to 450 injectors soon if that makes a lick of difference.
So far it looks like a slightly used itr pump or the warlboro if I can swing the price.
Trojan Man
02-16-2011 09:03 AM
