Where to "T" my BOV and wastegate off???
Old Jun 20, 2002 | 12:10 PM
zerofourLS-T's Avatar
New User
Default Where to "T" my BOV and wastegate off???
I used to have these 2 vacume based factors running off my main PCV, which i found wasn't teh best place for them. where should i T them off???
i don want to use the line directly to the left of the PCV because i have many things running off that already.
i know this is kind of a beginner question but i would appriciate all that have any input.
thank you
Old Jun 20, 2002 | 12:16 PM
CovertFI's Avatar
Default Re: Where to "T" my BOV and wastegate off??? (zerofourLS-T)
what about your fpr line?
Old Jun 20, 2002 | 01:46 PM
New User
Default Re: Where to "T" my BOV and wastegate off??? (CovertFI)
off that line i have my boost gauge and map sensor/check valves coming off it already. do you think it would be ok to splice more vaume off it.
i heard it you put too many things off one sourse..youo loose vacume pressure.
Old Jun 20, 2002 | 01:51 PM
CovertFI's Avatar
i dont know what the ls mani looks like but just t off of any line comming from the mani and you will be fine.
Old Jun 20, 2002 | 02:45 PM
paulzy's Avatar
splice into your brake booster line
Old Jun 20, 2002 | 03:28 PM
New User
Default Re: Where to "T" my BOV and wastegate off??? (Slow_ass_4dr)
the brake booster?
hmm is that the line underneth the throttle body?
Old Jun 20, 2002 | 03:50 PM
rjardy's Avatar
Just trace the line from your brake booster. You know where that is right? not being a dick just asking... HTH
Rob
Old Jun 20, 2002 | 04:52 PM
New User
Default Re: Where to "T" my BOV and wastegate off??? (rjardy)
No offense taken. im just starting out. im really not sure where the brake booster is.
Old Jun 20, 2002 | 09:39 PM
paulzy's Avatar
you know where the master cylinder is? The thing where you pour in brake fluid? The booster is the round black thing mounted to the firewall. There should be a vaccum line from there to the top of your intake manifold about 1/2" in dameter
Old Jun 20, 2002 | 10:33 PM
GSRgrrl's Avatar
The Brake booster has a 3/8" line. (At least that's what kind of vacuum T you will need to use on it.)
Heres a picture of the line in my car.
Pman92
Sep 19, 2007 04:59 PM
spark plugs.
Apr 28, 2004 04:58 AM
TypeDC4
Oct 23, 2003 05:13 AM
T25 civic
Oct 30, 2002 06:17 PM
Integra_Boi
Aug 13, 2002 02:10 AM
