hellp jdm headlights install
ok so i have jdm one piece to install but i cant even get my original oness off the frame and the bumper support is in the way is there anyway to remove the bumper support or an easy way to get my stock ones off?
hey. next time, please use the search button. people usually get flamed for not using it lol. anyways i found a link for you
http://www.absoluteprelude.com...ID=45
on a more serious note. if ur having problems installing headlights...maybe read up more about DIY's before attempting other DIY's.
note: on the wiring I "double grounded" ( took the extra wire from the 3 wire socket and grounded it with the negative on the 2 wire socket) and it made my lights a bit brighter. just a tip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 »</TD></TR><TR><TD CLASS="quote">
note: on the wiring I "double grounded" ( took the extra wire from the 3 wire socket and grounded it with the negative on the 2 wire socket) and it made my lights a bit brighter. just a tip</TD></TR></TABLE>
for mine i just got the part from passwordjdm.com plugs in to stock then into jdm then done
2 bolts are removed from each side of the front, I think they are 12mm.you will find it easier with a long extension and socket. behind each headlight there are a 12mm nut. You might want to remove your battery and power steering unit out of the way. While your at it, just remove anything that you feel isn't needed and it will be easier to get to everything.
97itypeR
Nov 15, 2006 02:38 PM
