forged pistons
Old Oct 14, 2007 | 06:59 PM
jabluecar's Avatar
Default forged pistons
thinking about going with wisco pistons, what has to be done to the block. i heard they are just drop ins but want to hear what you guys have to say. block is in perfect shape, thinking about pistons cause going force induction and want some insurance.
Old Oct 14, 2007 | 08:07 PM
doood's Avatar
been there done that
Default Re: forged pistons (jabluecar)
you're gonna need forged rods as well. depending on the current condition of your sleeves, you may or may not need a slight overbore.
either way, you need to set up the piston to wall clearances to what the wiseco spec sheet calls for.
Old Oct 15, 2007 | 04:11 PM
jabluecar's Avatar
thanks for the info. i dont think i wanna run rods, but im not sure yet im running a jackson supercharger on 10lbs not sure if i need them
Old Oct 15, 2007 | 07:54 PM
LastGenEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jabluecar &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info. i dont think i wanna run rods, but im not sure yet im running a jackson supercharger on 10lbs not sure if i need them</TD></TR></TABLE>
Then why are you buying pistons? The rods is what breaks and destroys your block. You should just run stock
Old Oct 16, 2007 | 03:44 AM
NJIN BUILDR's Avatar
Default Re: forged pistons (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">
Then why are you buying pistons? The rods is what breaks and destroys your block. You should just run stock </TD></TR></TABLE>
The stock rods are fine for most low hp builds,especially for moderate rpm.The stock cast pistons fail before the rods on a regular basis (ringlands).Wiseco pistons are fine on stock rods.A machine shop will need to swap them on the rods for you because they are press fitted to the rods.Standard pistons will fit the block if the bores are good enough not to need an overbore.
Old Oct 17, 2007 | 02:29 PM
jabluecar's Avatar
Default Re: forged pistons (NJIN BUILDR)
thanks for info njin buildr. thats what i was thinking, basicly i have all these parts and wanted to do something with it.i had a gsr block with 30k miles on it, head and supercharger, just parts that ive collected. i no that the pistons are the weak link like u said, so i am going to buy the wiscos, and i wasent sure about the rods. like i said befor im only going to run 11bls and no future upgrades.
horn12007
May 26, 2010 11:15 AM
Townson
Jan 7, 2009 08:43 PM
allmotor99lude
Jan 4, 2006 11:37 AM
Johnny_Rocket
Jun 11, 2005 12:13 PM
ntegls
Feb 22, 2004 06:11 PM
