FPR questions.
Old Oct 14, 2007 | 04:21 PM
DrivinVtec's Avatar
Default FPR questions.
I have 2 Honda FPR's. 1 has the B&M adapter on it an the other is completely stock. Im trying to find out if this stock will work. the both have nr-1 on it but under neither the have some numbers.
stock-FK7
B&M- TD28
I sold the B&M because i had 2 stock FPR's. but didnt notice that one was cracked so now i have 1. I want t make sure this stock one will give me the right pressure before i ship this one out tomorrow. Can I get some insight?
Old Oct 14, 2007 | 04:52 PM
lude98SH's Avatar
Default Re: FPR questions. (DrivinVtec)
Install a FPR gauge and find out.
Do you have a high flow pump or any aftermarket fuel system upgrades ?
Old Oct 14, 2007 | 05:21 PM
DrivinVtec's Avatar
Default Re: FPR questions. (lude98SH)
rail an pump. motor is out. i have no way to test it.
Old Oct 14, 2007 | 06:16 PM
DrivinVtec's Avatar
are all honda ones the same?
Old Oct 14, 2007 | 06:50 PM
DrivinVtec's Avatar
Default Re: (DrivinVtec)
Old Oct 14, 2007 | 07:56 PM
DrivinVtec's Avatar
any info?
Old Oct 15, 2007 | 06:11 PM
DrivinVtec's Avatar
okay..how about this. I have a D seriese FPR..will that work?
Old Oct 15, 2007 | 06:37 PM
DrivinVtec's Avatar
is this true?
if you are running the stock injectors it should be aroun 50-54 psi, if you are running obd 1 injectors it should be 36-40 psi. if you are running aftermarket injectors i cant say.
if so i no i have D series FPR. I using dsm 450's.
Old Oct 15, 2007 | 08:55 PM
DrivinVtec's Avatar
Old Oct 16, 2007 | 01:46 PM
DrivinVtec's Avatar
up
bcintron95
Jun 13, 2018 02:47 AM
JacksonD
Mar 26, 2010 07:13 PM
RTW DC2R
May 28, 2008 08:58 PM
mikegeezy
Dec 29, 2006 09:31 PM
redboost10
Jan 5, 2004 12:35 PM
