Engine Problem...Car stumbles/bogs out
Old Oct 10, 2007 | 05:09 AM
cjk95delsolsi's Avatar
Default Engine Problem...Car stumbles/bogs out
Here is the problem:
When driving my car, between 1500-3000 rpms under 20% pressure or more on the gas pedal the car hesitates/bogs out. If I hold the gas down the car loses all power and backfires at times. I have replaced the dist cap rotor and spark plugs. This seemed to work as a temporary solution but the problem is back. The car is not giving me any cels. Any ideas on the problem?
Old Oct 10, 2007 | 06:29 AM
Blk00EJ8's Avatar
Default Re: Engine Problem...Car stumbles/bogs out (cjk95delsolsi)
maybe a flat spot in your TPS sensor reading... get a voltmeter and test it
Old Oct 11, 2007 | 12:03 AM
Default Re: Engine Problem...Car stumbles/bogs out (Blk00EJ8)
do you know what amps or watts it shoud read?
Old Oct 11, 2007 | 12:10 AM
hondmywrld's Avatar
try a different oxygen sensor.. my car was doing the same thing except only between cold and fully warmed up...
Old Oct 11, 2007 | 08:25 AM
Blk00EJ8's Avatar
a voltmeter reads volts btw
0% throttle =~ 0.45 - 0.50 volts
WOT =~ 4.45 - 4.55 volts
btw there should be no flat spots when you open the throttle, i.e. the reading should not jump around at any point and should progress linearly up to 4.5 volts. if you have any flat spots or erroneous readings in between, get a new tps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjk95delsolsi &raquo;</TD></TR><TR><TD CLASS="quote">do you know what amps or watts it shoud read?</TD></TR></TABLE>
does the OP have a CEL?
Old Oct 17, 2007 | 03:39 AM
I dont have a cel.
Another thing is if the car is sitting at idle and i rev it up with full throttle and hold it the car will bog down and die as if it lost all power.
Old Oct 17, 2007 | 04:01 AM
Timberland237's Avatar
Default Re: (cjk95delsolsi)
did you check you fuel filter or pressure regulator?? sounds like it's clogging somewhere and it slowly looses gas or maybe even air.
Old Oct 19, 2007 | 12:34 AM
replaced the fuel filter, but havent checked the fuel pressure reg
Old Oct 23, 2007 | 11:48 PM
I have been doing some research on here and I have found several people with similiar problems and people are saying it the ignitor. Do you think this could be it?
THA DOHCTOR
Engine Management and Tuning
Jun 17, 2012 04:06 PM
bowdown201
Feb 12, 2009 11:01 AM
mrjingles8705
Honda Civic (2001 - 2005)
Jan 7, 2007 06:21 PM
crnimacak
Jan 19, 2006 04:59 PM
