clutch problems d16y7
Old Oct 9, 2007 | 11:06 AM
hifonics's Avatar
Default clutch problems d16y7
Well I just did the front brake's on my car yesterday and after I finished everything was fine.So we go to jack and grab something to eat,leaving jack my clutch pedal is really hard.And just to put it into perspective am 195lb and I've lifted weights before and it is pretty difficult for me to push in the pedal let alone hold it to the floor.So we swing by autozone on the way back and pick up some brake fluid so we can bleed the slave cylinder.After we bleed the slave cylinder same thing,the pedal is still hard.I don't have a clue what it could be,any help or suggestions would be appreciated.
Old Oct 9, 2007 | 12:11 PM
hifonics's Avatar
Default Re: clutch problems d16y7 (hifonics)
Damn nothing yet? it's cool am watching scarface anyways.
Old Oct 9, 2007 | 12:37 PM
924doorEG's Avatar
did u get on it at all going to jack?
Old Oct 9, 2007 | 12:47 PM
hifonics's Avatar
Default Re: (924doorEG)
Nope, and btw there's no such thing as going fast in a 4 door y7 lol.
Old Oct 9, 2007 | 12:55 PM
924doorEG's Avatar
oh btw my d15b7 4 door runs 15.7 so dont talk **** buddy. your on ur own.
Old Oct 9, 2007 | 01:11 PM
hifonics's Avatar
Ok can we stay on topic here please.
and btw I was'nt knocking your car or nothing don't know why you thought that.
Old Oct 9, 2007 | 01:16 PM
circuitEG6's Avatar
Default Re: (hifonics)
sounds like a bad slave, not the possibly even the sylinder, does it squeek like a bad belt when your not on the pedal at all??
Old Oct 9, 2007 | 01:21 PM
hifonics's Avatar
Default Re: (circuitEG6)
Nope, does'nt make any noises.And I only have to push the pedal down maybe 3 inches to go into gear.And it goes into all gears fine.
Old Oct 9, 2007 | 01:25 PM
circuitEG6's Avatar
sounds like a bad slave cylinder man, im not positive but thats what i would diag. at work if i got it...pretty cheap you just have to bench bleed them like a master cylinder...unless you know someone that thinks differently on what it could be
Old Oct 9, 2007 | 01:29 PM
hifonics's Avatar
Actually would a Bseries slave work? Because I've got a GSR slave laying around the house somewhere.
Old Oct 9, 2007 | 01:31 PM
circuitEG6's Avatar
yea the slave on the trans, but not the cylinder itself on the firewall...
Old Oct 9, 2007 | 01:35 PM
hifonics's Avatar
So then do you think I should replace both of them? Or is there a way of testing which one is bad?
Old Oct 9, 2007 | 01:43 PM
circuitEG6's Avatar
it sounds alot like the cylinder not the slave itself...usually when a slave is shot it squeeks like a bad belt when your off the clutch totally and you said yours doesnt do that, the only other thing it could be is the slave cylinder, since it regulates the clutch pressure and the amount of free play that it has, just replace it, bleed it, and go, no clutch adjustment at all, just on cable trannys...
Old Oct 9, 2007 | 01:49 PM
hifonics's Avatar
Alright well thanks for all your help very much appreciated.Up's to ya
Old Oct 9, 2007 | 02:15 PM
circuitEG6's Avatar
no prob bro, thats what everyone is here for!! good luck and let me know what happens!
Rude Awakening
Nov 11, 2008 08:39 PM
Zerophase
May 8, 2008 02:16 PM
gsr1289
Aug 22, 2006 07:11 PM
Xander teh Grate!
Nov 9, 2003 05:32 PM
TeamTooQuick
Aug 28, 2003 08:07 PM
