clutch slave Q
Daughter not possible
clutch slave Q
well starting yesterday the clutch engaged right off the ground, so I figured slave cyl, as I've gone through it before. Of course today, it was even worse. At first I couldnt even shift. But like the last time, performance seems to get better as you drive, but always leaves play in the pedal.
So I bought brake fluid and a slave. I open the cap, and only a smidgen would go into the car, but it seemed that over the drive, full function came back. So I just now parked it, do you think it needs the slave? (I have but unistalled)
It seemed to have gotten full range back, but the resivour was only a smidgen low, so Im not sure if that fixed it or not. I dont want to not be able to take off when I get off work in the morning.
Re: (Bakeoff)
yeah pull the boot off and if its not leaking your oaky,other than that look right under your clutch pedal and if its soaked with brake fliud or a slight seeep then its your master cyinder.
afropuffs808
05-02-2008 06:17 AM
gsr1289
08-22-2006 07:11 PM
