Ls/Vtec in Delsol What is needed
I searched and didn't see a detailed list. My friend is wanting to put a ls/vtec setup out of a 92 integra in his 93 delsol. What all is needed? Can we use the mounts and shift linkage off of a dc? There is a auto Dc at the junk yard, But no manual. Can any of the automatic dc mounts be used?
I know he needs the hydro to cable conversion. Is it any good?
you can use the shift linkage off of a GSR or even a DEL sol Si if you can find one, and the mounts for the b-series in the delsol are fine, just get the hasports b4 u swap it in, trust me its worth it...you cold use GSR axles too the spindles are the same and will fit perfect in the hub, but as far as the half-shaft im not sure dont remember lol. what kind of ecu u gonna be runnin?? everything else besides the linkage and axles will work fine and swap right in, i have an EG and the chassis is the same as the delsol obviously, that was all i needed to do my CR-VTEC swap...let me know how it goes!
Sadly to say since its a Del Sol you need shift linkage and rear trans bracket from a Del Sol. Im not 100% sure on the other mounts but i think you could use stocks.
Well it is the delsol with the d16z6. I think that was the si. When you say delsol si do you mean the one with the b16 or the sohc vtec? We have the whole swap out of my buddies Da ls/vtec. I am going to pull the motor later. I was going to use his axles,half shaft and knuckles. We have a p72 and a socketed p28. I am probably going to use the p28 since it isn't looking for a knock sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Sadly to say since its a Del Sol you need shift linkage and rear trans bracket from a Del Sol. Im not 100% sure on the other mounts but i think you could use stocks. </TD></TR></TABLE>
So I can use the sohc delsol trans bracket or the delsol b16 trans bracket?
He wants me to put in the motor but I have never done a swap in a delsol. I just want to know what all I need.
actually you can use rear tranny bracket from a 94-01 GSR too, but your going to need a DEL SOL VTEC (DOHC) shift linkage for this swap.
the d16z6 tranny bracket is different.
as for the rest of the swap, you can use same thing as you would use to swap into an EG chasis (axels, mounts, etc.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unkur »</TD></TR><TR><TD CLASS="quote">actually you can use rear tranny bracket from a 94-01 GSR too, but your going to need a DEL SOL VTEC (DOHC) shift linkage for this swap.
as for the rest of the swap, you can use same thing as you would use to swap into an EG chasis (axels, mounts, etc.)</TD></TR></TABLE>
x2, these things are true.
akunamatta
10
Jun 17, 2007 11:37 AM
hotimportcrx
Nov 3, 2005 09:51 AM
sshaikh01
Oct 6, 2002 03:30 PM
