you guys with swaps. I have yes or no questions for you guys.
I'm currently deciding which car to take up as my project car.
Civic w/b16 or integra with LS/vtec
for you guys who done b16s into civics.
1. Which axles are you guys using, the 88-91 integra ??
2. Which shift linkage ??
3. Do you need motor mounts since they already come with the engine ??
Re: you guys with swaps. I have yes or no questions for you guys. (sshaikh01)
I take it you're putting into the 96' in your sig?
1. I have a B16 in my 93 hatch and used the Del Sol VTEC axles that came with it.
2. Modified the Del Sol shift linkage to fit, but I beleive that "modification" is causing my tranny woes. I would suggest an integra or Si linkage.
3. I didn't need mounts for my chassis, the ones that came with it worked.
I have a B18C1 into my 93 Si
1. 94 Integra GSR axles with GSR halfshaft
2. 95 GSR Shift linkage
3. No, the integra mounts all worked on my car. The two lower mounts were a tight fit, there is a hump on the chasis that made it difficult to fit the integra mounts (Maybe it was a hump on the GSR mount and not the chasis, I cant remember). I think you can re-use the civic outer parts of those mounts and not worry about it. My GSR worked though, even with the hump.
Re: you guys with swaps. I have yes or no questions for you guys. (Slurp56)
Use whatever axles matches your Int. Shaft. Like I used a 90-93 Integra Int shaft so I used the cheaper 90-93 integra axles.
1. integra axles from 94
2. 94 integra linkage
3. rear monut from 95 integra, left and right are the same, but iused teg ones.
this is for my b18b, but im pretty sure its the same.
You want yes or no answers yet you have questions starting with "Which"?????
Re: you guys with swaps. I have yes or no questions for you guys. (96HatchB18)
FS in TN: B16 Engine, GSR Transmission, GSR Shift Linkage, Integra Axles, Integra Mounts, 92 Integra
92integraVTECgsr
12-01-2007 07:49 AM
